Remove Cluster Lid 2008 G35 Sedan?
Old Sep 25, 2011 | 11:03 AM
dice13's Avatar
I need to know how to remove the Cluster Lid on a 2008 G35 Sedan. I have removed the plastic cover and two screws located below the steering wheel as detailed on Infinitihelp but I still can't remove the cluster lid. Any thoughts?
Thanks.
Old Sep 25, 2011 | 11:09 AM
gshadyz's Avatar
don't do it man you'll regret it. your just going to *** it up if you remove it
Old Sep 26, 2011 | 02:21 PM
dice13's Avatar
I don't really have a choice. I need to have it replaced.
Old Sep 27, 2011 | 10:00 PM
G-MAN (CANADA)'s Avatar
Bring it to a dealer man, I can just see many problems arising from this.
Old Sep 28, 2011 | 12:34 AM
G3065's Avatar
Remind me is that the price above the steering wheel that is known for being "warped" as the dealer says
Old Dec 28, 2013 | 07:29 PM
botlfed98's Avatar
Thanks.
ever figure out how to remove it??
Old Dec 30, 2013 | 09:11 AM
infinitidude's Avatar
I have replaced probably a hundred of these things and if you haven't ever removed it you will probably cuss a little bit. It's tricky to get it off without removing the steering wheel especially with paddle shifters on the sport models. I would suggest taking it to the dealer they will probably charge around 2 hrs.labor to do it if I had to guess. All of the ones I've replaced have been under warranty.
Old Dec 30, 2013 | 10:10 AM
botlfed98's Avatar
Yeah def not for the faint hearted, pretty consumed...I've had steering wheel off several times and I don't see how you would get the lid off without removing it
Old Dec 30, 2013 | 10:29 AM
Column has to be lowered down as far as it will go and cluster lid assy. has to be rolled to the right around the column. It can be done with patience to keep from scratching top of steering wheel but easier if wheel is removed for sure.
Old Jan 3, 2014 | 01:22 PM
b-dRizZy's Avatar
for some reason mine has always been popeed open since i got my g.. and cant **** it back to normal
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
