g35 sedan 6MT rattling sound when idle
Old Oct 27, 2011 | 07:55 PM
elnad's Avatar
Exclamation
ok guys i just recorded this sound im getting from my clutch? when i hold the clutch down the noise goes away but when i release it it makes this loud noise. is this normal guys?
here's the video clip of it
http://s1127.photobucket.com/albums/...=VIDEO0013.mp4
Old Oct 27, 2011 | 07:58 PM
Quimby's Avatar
that's clutch chatter, but it seems very loud.
Old Oct 27, 2011 | 08:04 PM
elnad's Avatar
ever since i installed a custom magnaflow cat back it seems like the sound got louder
Old Oct 27, 2011 | 08:09 PM
PAIXAO's Avatar
Could be your clutch is on its way out. How does it shift?
Old Oct 27, 2011 | 08:50 PM
vqsmile's Avatar
Is there any possibility that (as a result of the recent work done) the exhaust or heat shielding is rubbing on the tranny somewhere? It could be that the chatter is resonating through the exhaust or shielding which amplifies it like a soundboard.
Old Oct 28, 2011 | 08:11 AM
07-G35-MT/S's Avatar
Mine is just like that. Infiniti replaced my tranny at 7k for input shaft bearing issue and excessive gear wine. So, the noise I have is post replacement. I'm at almost 94k. The noise doesn't bother me anymore. But, if you are under warranty, and have time on your hands, see what they will do for you.
Old Oct 28, 2011 | 04:16 PM
Wannabe6MT's Avatar
-MN G Crew-
Mine rattled quite a bit before too... almost sounded like a diesel...
It is much quieter now that I got a new transmission though.
Old Oct 28, 2011 | 08:33 PM
elnad's Avatar
did warranty cover your new transmission?
Old Oct 29, 2011 | 01:48 AM
Wannabe6MT's Avatar
-MN G Crew-
Yep, but I got it replaced for a 6th gear grinding issues completely unrelated to the chatter.
Old Oct 29, 2011 | 01:09 PM
Same here. 5th and 6th grind on top of the gear whine, all at 7k. Usually when something is manufactured wrong, it surfaces early.
Old Oct 29, 2011 | 01:14 PM
Quimby's Avatar
I thought my clutch was loud until I heard the two of yours.
Old Nov 8, 2011 | 07:29 PM
fwdsux's Avatar
I have the same problem, not nearly as loud. 5th gear also grinds, and I have never slammed a gear in this car. '03 6mt w/76k miles. It's still under warranty but the dealerships obviously stick with the excuse that it's "normal" and "nothing to worry about as they all do it."
Old Nov 8, 2011 | 07:54 PM
04WhiTe_G_Coupe's Avatar
I too was also wondering if that noise was a normal thing for our cars. Glad I found an answer to my question. Mine only makes the noise after the car is at running temp and the clutch is in neutral.
Old Nov 8, 2011 | 08:31 PM
04G35NYC's Avatar
i have heard like 4 6mt second gen sedans and have the same noise. I think this is perfectly normal as i understand.
Old Nov 9, 2011 | 11:49 PM
  #30
OMG35S's Avatar
I think mine does it too but it's not that loud as posted in the video...
Pretty sure it's normal on our cars.. Although it shouldn't be too loud.. I don't notice it unless I'm standing next to the car trying to listen to it..
