g35 sedan 6MT rattling sound when idle
Old Dec 22, 2019 | 09:41 AM
  #31
countryboy's Avatar
Black g35 purchased from auction with 190k now has used motor with 50k
Gears grind
Originally Posted by 07-G35-MT/S
Same here. 5th and 6th grind on top of the gear whine, all at 7k. Usually when something is manufactured wrong, it surfaces early.
what is the reason my gears grind in my 03 g35
Old Dec 22, 2019 | 10:39 AM
  #32
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Worn synchronizers, you can limp it along with a transmission fluid change, switching to Redline MT-85 is even better. Early model G35's had fewer synchros than later models so the issue is even worse.
This is just what happens to manual transmissions when they wear out.
Old Dec 23, 2019 | 10:51 AM
  #33
countryboy's Avatar
its funny cause i also have a 95 honda accord with well over 200k miles on manual transmission and it goes into gear so smooth
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
nervseele
Jul 17, 2015 11:21 PM
