Benefits of installing an oil cooler
Old Oct 9, 2011 | 01:07 AM
kendroz's Avatar
My car is a G35S 2007 with some minor mods. I noticed that the car has a trasmission cooler. Can I install an aftermarket oil cooler to prolong engine life? Side benefits?
Thanks to all
Old Oct 9, 2011 | 01:21 AM
herrschaft's Avatar
Unless you track your car regularly, I highly doubt you will need an oil cooler.
Old Oct 9, 2011 | 06:03 AM
Defratos's Avatar
You're Despicable
a member on here has already done this a while back ---> https://g35driver.com/forums/v36-eng...installed.html
as mentioned above you won't really benefit unless you either track the car or if you're going with forced injection.
on a side note where are you located? because I thought US spec cars don't come with a transmission cooler (only GCC and *** models)
more links on this subject:
https://g35driver.com/forums/v36-eng...il-cooler.html
https://g35driver.com/forums/v36-eng...r-removal.html
Old Oct 10, 2011 | 01:59 AM
kendroz's Avatar
Thumbs up
Sorry I belive it is the power steering cooler.
I live in Puerto Rico and my car is US specs.
Thanks for the links, they are very helpful.
Iám looking for installing and engine oil cooler and last night I found that stillen has one for $432. I saw that all people are in favor of setrab brand.
Thanks and take care
Old Oct 10, 2011 | 03:24 AM
Defratos's Avatar
You're Despicable
Yeah engine oil cooler is a little harder to upgrade, from what I remember it was somehow connected to the Radiator or something...Can't remember and yes Setrab is a good brand.
Good luck
Old Oct 10, 2011 | 05:40 AM
E-Ticket Ride's Avatar
As others have asked, why do you feel you need one?
Old Oct 10, 2011 | 12:09 PM
vqsmile's Avatar
+1
Old Oct 10, 2011 | 11:30 PM
kendroz's Avatar
To help the engine to be cooler and sometimes I go to the track and noticed that after some 1/4 mile passes the ET is not the same.
Old Oct 10, 2011 | 11:46 PM
That's most likely heatsoak, all other things such as 60ft, etc being the same.
IMO, unless you roadrace/track the car where youre running it for prolonged periods of time (I.e. not 1/4 mile runs), then it's a waste of time/$$
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
saskicker32
Aug 11, 2015 02:12 PM
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
