Near 100K, dreaded "service engine soon"
Old Nov 9, 2011 | 10:12 AM
Calpolytlo's Avatar
Driving to work this morning and I'm literally at 99,979 miles. . . and the
effing service engine soon light comes on!
Could it be a simple maintenance reminder at 100k?
The tranny fluid change is over due. . .but I doubt this is the problem . .. any ideas anyone?
**2007 G35S Sedan AT
Old Nov 9, 2011 | 10:23 AM
mishmosh's Avatar
You can scroll through the service reminder menu to see what it is set at. I personally turned mine off.
A check engine light needs to be read. Since you have a lot of miles, I think it's worthwhile for you to go and buy a OBDII reader and see what diagnostic code(s) get pulled.
Old Nov 9, 2011 | 10:31 AM
Calpolytlo's Avatar
Yeah I turned my service reminder off as well. . .
power steering fluid & coolant were a tad low . . . I'll try that on my lunch break
Anyone know if the car has sensors to measure these fluid levels?
Old Nov 9, 2011 | 10:47 AM
Hotdawwgman's Avatar
Most likely a 02 sensor... But I would still get the code read... Don't be lazy on changing fluids..... It will cost you more in the long wrong
Old Nov 9, 2011 | 11:19 AM
willdogs's Avatar
Not to be a dyk, but if this is how you keep up with the maintenance on your car, then don't be surprised or angry when things start breaking
Old Nov 9, 2011 | 11:25 AM
Calpolytlo's Avatar
You're being a "dyk" to assume so much. Oh what every time you check your fluid levels they are where they should be? Or are there times you need to top them off? So does that mean you don't maintain your car?
GTFO
100K soon and this one minor hiccup.
Old Nov 9, 2011 | 11:37 AM
willdogs's Avatar
LOL, don't get touchy.
I never assumed anything, you admitted that your fluids were low, so it's a fact, not assumption.
I open my hood about once or twice a week and make sure all is on the up and up. if something is low or is scheduled to be changed, I do it right away.
Guess I'm a bit OCD about it.
Good luck
Old Nov 9, 2011 | 11:43 AM
Calpolytlo's Avatar
Good luck
no harm . . . I do get touchy about my car! regular wax, regular maintenance(i'm only 5k off my tranny flush).
lol yea I most def dont check fluids that often.
Old Nov 9, 2011 | 11:47 AM
G3065's Avatar
most likely an 02 sensor... or maybe a spark plug. take it to autozone they will let you know for free. gluck
Old Nov 9, 2011 | 11:53 AM
Calpolytlo's Avatar
Didn't know they offered that service. So they will check the code free of charge?
Old Nov 9, 2011 | 12:02 PM
kool_yaar's Avatar
^ yup and like he said its probably o2 sensor or plugs imo
Old Nov 9, 2011 | 12:44 PM
G3065's Avatar
Yes sir. keep us posted... At this rate that I'm putting mileage on my G I will probably run into this type of issue.
Old Nov 9, 2011 | 01:25 PM
Calpolytlo's Avatar
will do
Old Nov 9, 2011 | 03:15 PM
Mr.tnismo's Avatar
Auto Zone does a free "Check Engine Light" check. They wont fix it, but they will tell you the code.
Old Nov 9, 2011 | 03:34 PM
funkydrummer's Avatar
^ Same with Advanced Auto, you can read the error code and clear it as well.
