Having trouble with car not starting
Old Nov 18, 2011 | 01:34 AM
bati's Avatar
My wife's car 07 G35 wont start all the lights on the dash light up and everything, and there is no clicking noise. I just replaced the battery today and the car wont start at all. I looked through the fuses and couldn't find a blown fuse. I've read through some threads and some mention that the throttle needs to be clean and the other says that the car might be disabled by the alarm. can you guys please help me out with the problem at hand.
thanks
Old Nov 18, 2011 | 02:53 AM
sdbolt's Avatar
I'm not a car guru but the same thing happened to our benz. Our mechanic changed the crankshaft position sensor and now everything is fine. Once again, I am no expert and I don't even know what a crankshaft position sensor does...
Old Nov 18, 2011 | 03:49 AM
bati's Avatar
Do you know the location for the 07-08(G35)of crankshaft position?
I found this:
https://g35driver.com/forums/engine-...n-sensors.html
but I'm not sure if its the sensor you're talking about
Old Nov 18, 2011 | 09:05 AM
turbo_rp's Avatar
if the crank sensor is bad the the car will turn over but not start one way to find out if it is bad is to check for spark...
Old Nov 18, 2011 | 10:01 AM
Ketchup83se01's Avatar
does the car turn over, meaning does it crank but doesnt start? Did you try jumping it
Old Nov 18, 2011 | 10:24 AM
BionicG35's Avatar
could be a bad starter, starter button, or maybe a security system disable. If the battery was replaced without the use of a memory saver it is possible the security system has disabled the car. I suggest calling a Nissan or Infiniti tech and ask about that possibility.
does the "apply brake" icon appear on the cluster display?
Old Nov 18, 2011 | 12:01 PM
bati's Avatar
How do I check for a spark?
Old Nov 18, 2011 | 12:03 PM
bati's Avatar
it doesn't start at all I pressed the start button and all hear is click sound. All the light in the interior do start. we did try to jump the car but that didn't work thats why I got a new battery.
I was told too that the battery was not holding the charge.
Old Nov 18, 2011 | 12:05 PM
bati's Avatar
the apply brake does appear when the key is around the ignition.
I pressed the brake and the start button but I don't hear a crank
Old Nov 22, 2011 | 10:17 PM
bati's Avatar
*Bump*
I was quoted 1818.56 to replace valve body. (TCM not responding in system call for Trans) by my local dealer. what do you guys think.
thanks,
Old Nov 23, 2011 | 01:58 AM
**** that sucks man, try finding a used tcm if thats what they're gonna replace its just a little computer, why are they gonna replace the valve body isn't that used for shifting gears dont see how this relates to it not starting
Old Nov 23, 2011 | 02:09 AM
bati's Avatar
where is the TCM located? I think they are charging me too much for what they want to do.
I was originally thinking that the ECM just had to be reset but they told me NO.
Old Nov 23, 2011 | 09:32 AM
BionicG35's Avatar
TCM has nothing to do with starting the car
Old Nov 23, 2011 | 12:29 PM
bati's Avatar
The dealer says that the TCM is not communicating with the ECM and not letting the car start
Old Nov 23, 2011 | 01:29 PM
mishmosh's Avatar
Did you hear cranking with the old battery or just not with the new one? I would be surprised if something like a TCM disabling the ignition would not light up a check-engine light. I am kind of surprised that something with the auto tranny could prevent startup but these cars are so damned complicated nowadays!!!
