So I have a extra cluster that I was going to do a LED swap on the centre info read out. After pulling it all apart I've decided against it. I could swap out any of the other L.E.D.'s but it's the info readout I wanted to change. It would easier to buy a 09+ Gauge cluster and just swap the LCD screen. But pics for fun.
whs^^ interesting pictures now i know whats behind the scenes
Quote:
Nope. The cluster is 100% usable. I've already re-assembled it.Originally Posted by salvador312
So this cluster is not longer usable?
Can that be done? Can you swap gauge clusters from the 09+ models? I'd really love to do this, the blue LED screen is much better in my opinion, one thing I really liked about them.
TunerMax
close
- Join DateDec 2011
iTrader Positive Feedback100
iTrader Feedback Score(3)
- My RideG35
Liked:359 Times in 258 Posts
Quote:
Really? So you pre-calibrated and marked the needle location before you pulled the needles?Originally Posted by MrRage
And you renistalled and re-calibrated them?
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
+1 Granted, it can be done, but it's typically not within the average DIY'ers realm of expertise. Maybe he's got it goin' on. Originally Posted by TunerMax
Really? So you pre-calibrated and marked the needle location before you pulled the needles?And you renistalled and re-calibrated them?
TunerMax
close
- Join DateDec 2011
- My RideG35
Quote:
Peeeer haps.Originally Posted by vqsmile
We'll have to wait for him to chime in to find out
The needles lock at the same point they come to rest at. They were marked in this location. They were not hard to get off. This is not my first gauge cluster disassembly
TunerMax
close
- Join DateDec 2011
- My RideG35
Quote:
Granted, I'm unfamilliar with the 2007/08 clusters. As far as I've ever seen on any clusters, the spot that they 'stop', is where the needle hits a mechanical stop on the calibrated end (~0~), and where the end of the wind is on the upper limit.Originally Posted by MrRage
They're calibrated backwards from the upper limit normally.
This means if you removed the mechanical stop from the speedo, the needle would actually drop more.
I've done a lot of clusters too, and I've NEVER heard of one that you didn't have to pre-calibrate before removing the needles.
Granted, you CAN ofcourse, NOT calibrate them, and they'll "work" but they'll be way off on their readings.
