I have a 2007 G35 Sport with Adaptive Headlights, aka AFS, they do not work. They don't turn in either direction, at stop in park, or in motion. No error codes, any idea how to diagnose this problem or where to even start? Where does the AFS get its read out for the steering wheel being turned? which module controls it?
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
It's pretty complicated; too much so to try and do justice in a posting. I'd suggest downloading the FSM ( which can be done for free) and looking it up under the EXL section, page 19. Basically, there's a control module for it that taps into the CAN communication bus to read all necessary sensor values and then it controls/monitors the motors which actually move the headlights. The manual can be downloaded at Infinitihelp.com for free once you register there. G/L
Dumb question, but you didn't turn the AFS off via the button to the lower left of the steering wheel by mistake did you? Check it out.
Turning AFS off would illuminate a dash light. So AFS worked and just stopped one day, or has it not worked since the car was purchased?
Alright, strangely enough I disconnected the battery, and afterwards they are back to working. In a few days I'm going to hook up a Nissan Consult and login to the module, see if theres any error codes.
and lol, yes I know how the AFS switch works.
vqsmile
close
- Join DateOct 2010
Quote:
... I disconnected the battery... going to hook up a Nissan Consult and ... see if there's any error codes.
Won't the codes have been cleared?Originally Posted by dimsler
Quote:
No most modules in modern cars retain memory. Originally Posted by vqsmile
That being said, there was no fault codes. Very strange problem.
vqsmile
close
- Join DateOct 2010
Ehh . . . I think depends on the module and the type of fault being recorded. AFAIK, non-critical faults are often volatile.Originally Posted by dimsler
No most modules in modern cars retain memory. That being said, there was no fault codes. Very strange problem.
I was wondering if anybody has tried installing the system into a non-AFS equipped vehicle?
Quote:
Anything is possible with enough money, but the parts alone will probably cost a grand or two, totally not worth it for what it does.Originally Posted by Dragonslayer
I have it and it's nice to have, but no way worth the money to retrofit it.
I have the premium pkg but not the tech. Before getting my current vehicle the only ones that i saw had the tech pkg had navigation which i didnt want.
vqsmile
close
- Join DateOct 2010
Quote:
+1 For my purposes, just seemed like a quick waste of $2000+. Originally Posted by Dragonslayer
...Before getting my current vehicle the only ones that i saw ... had navigation which i didnt want.
