end is nigh
Old Feb 9, 2012 | 08:10 AM
finallygot1's Avatar
end is nigh
About to take the g sedan in for final factory warranty work. No issues. 30k work just done before purchase at 28k. Still under 30 on the odo.
Anything I need to push for? I have an extended Elite warranty from same dealer.
Old Feb 9, 2012 | 10:28 AM
bluedevils95's Avatar
Did you get the new door pulls and steering wheel?
Old Feb 9, 2012 | 11:59 AM
rvanderwerf's Avatar
you can try the sunroof plastic trim on the outside.. my dealer wouldn't do it though, worth a shot
Any rattles, have them look at. Extended warranty doesn't cover that.
Old Feb 9, 2012 | 12:39 PM
stockae92's Avatar
my dealer wouldn't do the sunroof plastic rim neither
the wind shield tapping / clicking noise?
Old Feb 9, 2012 | 12:52 PM
vqsmile's Avatar
Common fixes covered include replacing scratched/chipped door pulls and steering wheel, replacing dash cover (over speedo) for peeling/lifting at left side, replacing and/or double-stick taping of door weatherstrip gaskets, sunroof trim (rarer though), and brake judder repair work.
There could be others, but those are the ones I see mentioned here the most.
Old Feb 9, 2012 | 05:39 PM
Car is solid, no trim problems I notice. Only mar is curb rash on one wheel. Notice a whine from a door lock servo Ill point out.
Old Feb 9, 2012 | 05:41 PM
Shocks struts aren't covered Im sure.
Old Feb 10, 2012 | 03:38 PM
scratched/chipped door pulls = do you mean on the inside if the door? If so then the passenger side may need attention.
Old Feb 10, 2012 | 04:35 PM
yes.. they call them 'door finishers'.
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Jeff T
Sep 30, 2015 02:00 PM
9tray turbo
Sep 29, 2015 10:22 PM
