For 6MT: How often do I have to change the transmission and diff oil?
Old Feb 9, 2012 | 07:17 PM
stockae92's Avatar
For 6MT, how often do I have to change the transmission and diff oil?
Old Feb 9, 2012 | 07:18 PM
JacekPSUr6's Avatar
^ I believe every 30K miles.
Old Feb 9, 2012 | 09:37 PM
vqsmile's Avatar
The "Premium Maintenance Schedule" which IS NOT REQUIRED, calls for every 30K, if you look at schedule 1 and 2, they do not. Regardless, I did do it at 30K and was glad I did. When my 5 - 6 synchro went out at 45K, the very first thing they asked me about it, was did I do the 30K service, and if so, what lube did I use. I was glad to be able to say yes, and I had used GL-4 rated lube, and had receipts to back it up if they wanted to check (they didn't).
Old Feb 9, 2012 | 09:54 PM
HenryLee's Avatar
did both of mine at 35K and will do the next at 70k and 105k
Old Feb 10, 2012 | 02:44 AM
808MIKE's Avatar
Hmmm I was wondering this same thing? I Hardly Drive my G..Mostly on Weekends..it'S an 07..I jus broke 20,000mi...So When Would be a good time for mne to change the Diff and Trans? I only change the Engine Oil..So Wondering when Do I do the rest? LOL I only put on at Most 3-4000mi a Yr! LOL. Do I half to wait to Hit 30K in couple yrs? LOL...
Old Feb 10, 2012 | 04:57 AM
Moki87's Avatar
Dont go Infiniti
Try going to Nissian dealer I believe its "cheaper"
Old Feb 10, 2012 | 12:42 PM
vqsmile's Avatar
You should be just fine waiting until 30K. It's not like it's lubricating the inside of a combustion engine with huge variations in heat, humidity, combustion residue, acids, etc. The tranny and diff are both sealed cases with heavy oil in them. Relatively speaking, it's a pretty easy life for them; 30k is nothing.
Old Feb 10, 2012 | 12:44 PM
G35SedanGrn's Avatar
If your infiniti service advisor likes you he will match nissan's price. They did for me.
Old Feb 10, 2012 | 07:19 PM
kool_yaar's Avatar
i did it at 45k and the MT fluid was in a very good shape however the diff was pretty bad which i recommend at 30k for sure!
Old Feb 10, 2012 | 07:28 PM
william747400's Avatar
Yep +1 on the 30K but a little over won't kill your car unless you are racing it.
Old Feb 11, 2012 | 01:49 AM
Nismo86's Avatar
I've seen the tranny DIY, but not the diff. Is there one for the diff?
Old Feb 11, 2012 | 02:26 AM
jbwrecked's Avatar
Now what kind of fluid do you guys use for the tranny and diff? Just for diy purposes
Old Feb 11, 2012 | 03:21 AM
Wannabe6MT's Avatar
-MN G Crew-
I kinda want to switch my fluids over to Amsoil. But i know Nissans are finicky about their tranny fluids, so i haven't been sure...
Old Feb 11, 2012 | 03:28 AM
Shanes_G's Avatar
i did a full swap of all my fluids to amsoil.
Old Feb 11, 2012 | 03:58 AM
Wannabe6MT's Avatar
-MN G Crew-
Did you notice any difference in fluid feel in the gearbox or anything?? Mine gets really notchy in the cold..
