Camber Kits + alignment with Eibach HELP!
Hey guys, so as i was reading through the forum i decided to go with the Eibach pro kit drop on my 2007 G35 sedan. reason for going with these was because it looked like not much was needed to lower it (ie upper and lower control arms to adjust the camber) however, i took it to the shop today and was told i need to get some adjustable upper and lower control arms along with the possibility of a rear camber bolt.
Any suggestions on what i actually really need? this is my specs as of right now. no modifications have been done. also they ran the specs with the OEM set up of 18 in wheels. anyone have specs for 19s?
my current set up is 245/35/19 in the front and 275/30/19 in the rear.
I wouldn't worry about the camber in the front. Our front tires don't wear very quickly so just have them get the toe to zero. I'd just get the Eibach rear camber kit (same as the SPC but less expensive) which will come with the toe bolts if they're needed. I was able to get my toe specs in the rear almost to zero with the Pro-Kit with the OEM toe adjustment. Our cars eat the rear tires quicker than the front so this is where I'd focus my $$$ to save $$$.
jraborg86 (03-05-2012)
You may just need the SPC/Eibach toe bolt for the rear. I'm lowered a bit more than Eibach so I got the F&R SPC arms and toe bolt but many w/ Eibachs get away w/ just the toe bolt kit. You can DIY w/ a dremel tool and about an hour grinding and installing, not too bad if you have the tools IME.
I know I am in spec on the rear toe, I am just hoping it is close enough to spec to not cause issues.
Are you sure you're looking at the right FSM? Mine shows a caster of 7.33 - 8.83 for 19" wheels.
