lost OEM lug key :(
Old Mar 7, 2012 | 12:42 PM
GXXXV X's Avatar
lost OEM lug key :(
i cant figure out how or where i lost it, and i need to take off my OEM wheels soon to lower my BCs more, but i cant do anything without the lug key. Anyone know about this? Like do i have to get a whole new set of lug nuts w/ key, or would Infiniti be able to send me the matching key for the pattern on my OEM lugs? Any idea on cost?
thanks
Old Mar 7, 2012 | 12:53 PM
G3065's Avatar
This happened to me as well and I just went to the parts department and they brought out a whole bunch of key's to try on my wheels and they found a match. I just bought the key btw didn't have to buy new lug nuts.
keep us posted!
Old Mar 7, 2012 | 01:01 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
you basically have two options at the dealer,
Have them try out the master lock set, remove your old locks and give you a new set comes with key 45-60$
Have them try out the master lock set, find the number you need and have the dealership order a replacement, 7-10 days to get, 25-35$
Old Mar 7, 2012 | 01:03 PM
PREMIUM SPONSOR
and this is not an over the phone type transaction, you have to go to the dealer,
if you bought it new, you have a wheel lock key number tag in the literature kit/new owner package also
Old Mar 7, 2012 | 02:25 PM
aquabat0587's Avatar
This happened to me too. I went to the dealer and I had them remove them and replace them with regular lug nuts. I must have caught them on a good day because they gave me all new lugs for free.
Old Mar 7, 2012 | 02:35 PM
soundmike's Avatar
Not sure how the OEM G locks look, but if it's the same i used to have in my old Nissan (as well as an old Acura) you can grip them using Gator Grips.
Old Mar 7, 2012 | 03:56 PM
E-Ticket Ride's Avatar
They look like this Mike, might be hard to grip since the design is on the face and not the outer lip:
I say go down to the dealer and have them figure it out.
Old Mar 7, 2012 | 05:40 PM
Anton_Chigurh's Avatar
If you don't mind ruining them..just hammer on a tad smaller socket..they will be junk after (socket and lug)
Old Mar 7, 2012 | 08:10 PM
nghiars's Avatar
all viable options people posted here. Take your pick OP.
Old Mar 8, 2012 | 02:21 AM
vqsmile's Avatar
Phil from Grubbs nailed it, but if you ever have to DIY, these work great, and you don't ruin a socket.
http://www.searsoutlet.com/Bolt-Out-...52&mode=seeAll
Old Mar 8, 2012 | 07:49 AM
soundmike's Avatar
It looks similar, but hard to tell how thick those ridges are, i'd be interested in trying that someday.
Old Mar 9, 2012 | 11:00 AM
GXXXV X's Avatar
Does Nissan have the same style lugs/locks? Jw cause my nearest Infiniti doesn't have a parts dept...or do I want service dept?
And no I would not be comfortable putting on regular lugs, I already have gotten free ones from the dealer but I want the security of knowing fewer wheel thieves have the appropriate key for the special lugs
Old Mar 9, 2012 | 11:08 AM
PREMIUM SPONSOR
Nissan, might have them if it's the same as the Z's.....
Sedan - 999W2-JT000
Coupe - 999H1-A7003
Old Mar 9, 2012 | 04:54 PM
dimsler's Avatar
Sedan - 999W2-JT000
Coupe - 999H1-A7003
999W2-JT000 - mag seat / shank lock nuts for v36 style wheels.
999H1-A7003 - acorn seat lock nuts for older v35 wheels.
Old Mar 9, 2012 | 09:39 PM
The outside is totally smooth and cylindrical. The inside, where the design/pattern is, isn't too deep. I imagine you could get a needle nose plier in there, but I doubt you could grip it enough to turn it since it should be torqued to 80ft/lb
