Putting stock springs back on
Mar 31, 2012 | 01:03 AM
Just installed my front Eibach Springs Pro-Alignment Camber Caster arms 5.72130K and aligned it. I installed the camber caster kit for the rears when I lowered it 3.5 years ago. I got all of the specs spot on except my left rear camber is just a bit off.
I wore out my first set or tires at about 30000 miles. My rears wore very evenly, but the fronts were worn quite a bit on the inside tread but had a good bit of tread left on the rest of the tire.
Make sure you check your tire tread ware... ratings. Its a driving factor in how long your tires will last, regardless of alignments.
Reply 0
Apr 26, 2012 | 09:42 AM
Update: So being i love my car lowered i ended up taking your guys advice and took it to 3rd alignment shop. While i was there the owner told me i have to wait in the waiting area i said no i wanted to be there while they do my alignment. Anyway i was in my car while the car was up on the lift, they made holes for my toe bolts and all. While i was in my car i was looking at the alignment screen and finally got my alignment all set. Everything in green.
Again thank you so much guys if it wasnt for you guys and your input i would have loved my car a little less.
Reply 0
