Windshield Sprayers
Old Apr 13, 2012 | 10:16 AM
3-fity's Avatar
Windshield Sprayers
I'm not sure if it is something that was corrected after '07 or not, but my windshield sprayers are complete garbage. They consistently clog and then just dribble out liquid.
I have noticed on the '12 that the sprayers are more of mister. Does anyone know if these can easily be replaced with the newer nozzles?
Old Apr 13, 2012 | 12:10 PM
kool_yaar's Avatar
iv never had any problems with my 07 sprayers, never clogged even once, my guess is you poured regular a water into the reservoir that can cause the sprayers to clog up at times, iv always used windshield fluid which is basically for winter but since its made with distilled water it does not clog anything up.
If you still have problems then im guessing the '12 sprayers should be a straight forward swap
Old Apr 13, 2012 | 12:13 PM
willdogs's Avatar
Stick a sewing needle carefully in the sprayer holes to clear clogs
Old Apr 13, 2012 | 12:17 PM
bluedevils95's Avatar
Never had a problem either. Did you stick a needle in the holes yet?
Old Apr 13, 2012 | 12:23 PM
surfjax87's Avatar
I had one clog a while back, just stuck a needle in it and all was good. FYI, you can also reaim the sprayers by sticking a needle in them and gently pulling the desired direction. Just remember a tiny movement with the needle results in a pretty large change in where it hits the windshield.
Old Apr 13, 2012 | 02:42 PM
muyrec's Avatar
An air compressor works really well also.
Old Apr 14, 2012 | 04:14 PM
kristof's Avatar
Mine sprays big streams, and I'd like them to spray a mist. I'm going to replace them soon.
Old Apr 14, 2012 | 04:44 PM
vqsmile's Avatar
Did you get some debris into your reservoir perhaps? Like others here, I've never had a single issue with my '07 either, so yours may just be a fluke.
Old Apr 14, 2012 | 06:32 PM
Q8y_drifter's Avatar
08 sedan, I live in a pretty dusty climate but they clog up all the time. I use regular water, nothing special.
Dallsinghjr1
Sep 17, 2023 11:25 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
NailBomb
Oct 28, 2015 07:53 AM
blueslatebenny
Sep 23, 2015 01:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
