Plastic Cover Gone.....
Old Apr 26, 2012 | 09:34 AM
Fendi35's Avatar
So the other day i was on the highway (nighttime) cruising at 71 mph when there was something on the highway.. tried to avoided coudent ran over it after running over it i saw right underneath my car in my rear view mirror just disintegrate. What it looked like was a huge piece of mud that was harden that fell off one of those construction trucks.
Anyway i herd something scrapping pulled the car over my license plate hider that was underneath my car was destroyed ( the plastic cover that holds it, and my license plate was all messed up) so i went to take it off then i saw my plastic cover the one that covers the oil pan was hanging on my car so loose that i just ended up pulling it off. Now i have the big piece of the plastic underneath my car is on but its like hanging and the the other piece that covers the oil pan is completely gone i took it off. Gots to love the roads in ny state.
Now my question is should i worry about replacing that piece of plastic and if so i would like to buy the whole piece both the bigger one and the smaller one, now i have no idea where to look for this.
Any help would be greatly appreciated .
Thank you.
Old Apr 26, 2012 | 10:34 AM
vqsmile's Avatar
The big panel is about $100. you can find them used at a wrecking yard, or pick up a new one from a discount dealership. Here's a random one that came up qickly under a google search.
http://discountinfinitiparts.com/par...iagram=3841030
I'd also suggest checking with Phil@GrubbsInfiiniti. They
are sponsors here and good folks.
Old Apr 26, 2012 | 10:41 AM
fillup's Avatar
You could replace it with an aluminum one.
https://g35driver.com/forums/exterio...-g37-g37x.html
Old Apr 26, 2012 | 12:30 PM
soundmike's Avatar
I couldn't tell from your description, but if the cover is relatively intact then it may have just been the clips that broke.
If that's the case, just get new clips.
Old Apr 26, 2012 | 12:37 PM
Austin713's Avatar
dangit! add that to the list of things i want.
Old Apr 26, 2012 | 01:12 PM
Fendi35's Avatar
Thank you
Old Apr 26, 2012 | 09:02 PM
vqsmile's Avatar
Good point Mike. Sometimes you can also use washers under the bolts to spread the contact out a bit if the cover has holes that have been torn through around the holes.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
