Clutch engagement question
Old Apr 30, 2012 | 11:12 PM
SAMzG35's Avatar
G35
How do I check if my clutch is fully engaged?
I just installed the RJM bracket and just wanna make sure it's all going well.
Old May 2, 2012 | 05:52 PM
jsolo's Avatar
There should always be a small amount of play in the pedal itself. The play should be before the pedal actually starts acting on the MC plunger. This ensures full clutch engagement with the pedal fully off the floor.
How small? That's up to you. Stock has about 1/4-3/8" of an inch.
Some folks don't like this play and have adjusted it out. I suppose you could do that, but it's not something i'd do on my car. This play also permits for slight expansion/contraction as the trans parts heat up/cool down.
Another way to check is to be in 3rd/4th gear, ~40 mph, and punch it. If the rpm's increase in proportion to speed, you most likely are fully engaged.
What do the instructions that came with the RJM bracket suggest?
Old May 2, 2012 | 06:54 PM
SAMzG35's Avatar
G35
same as what you said about the play, but i wanted to check again to make sure
I emailed Ryan (RJM) and he responded back right away, but the msg went to junk thats why i created this thread lol
Old May 2, 2012 | 09:46 PM
saywat?'s Avatar
i have no play.but i did notice my bros 350z and 335 had play i thought it was abnormal so my pedal is actually the abnormal one?
Old May 3, 2012 | 12:27 AM
jsolo's Avatar
@sam, what was his reply?
@saywhat, yes.
Old May 3, 2012 | 12:49 AM
SAMzG35's Avatar
G35
My question was "how do I check if the clutch is fully engaging/disengaging ?"
Originally Posted by Ryan@RJM
There's no worries on the clutch not fully engaging as that issue only exists with the factory setup. As long as the pedal returns all the way to the top and isn't forced hard up against the upper switch plate (same deal as the lower switch with a slight gap) then there isn't any chance of slippage caused by the pedal install.
For checking the fully disengaging you just need to do the tests outlined on the last pages of the install guide. Real quick though if the clutch is still dragging severely with the pedal fully depressed then you won;t be able to get into first at all. It'll be totally blocked.
If*its just dragging slightly then you'll feel resistance pushing into first followed by a "Bump" feeling in the shifter as it clunks in. In either case you'd need to turn the clutch rod out some until it goes away or lower the AFP setting slightly and try again.
I've found that with my factory clutch I'm good on all tests with the initial friction point set to roughly 3/4" to 1" up from the bottom hard stop. You can test this on level ground by coming to a complete stop, clutch in fully, go to first and then very slowly let the clutch up a little at a time and see just where the RPMs start to dip and the car just starts to creep forward. If it starts to creep right at the floor then you need about 1 additional turn out on the clutch rod to raise the friction point a little.
Old May 4, 2012 | 09:31 PM
saywat?'s Avatar
@saywhat, yes.
i guess i do have some play . my pedals jus not as loose as the other cars where the play is really obvious. my pedal is still stiff within the play range so thats why i never noticed it. does this sound right for other 6mt g35s out there?
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
