Finally broke down and got alignment kits installed.
Old Sep 6, 2012 | 10:45 AM
Gitsum's Avatar
Much appreciated I either lost the template or never got it when I did my toe bolts. How much material is being cut away? Doesn't look like much at all.
Old Sep 6, 2012 | 11:02 AM
TomPeters's Avatar
http://www.spcalignment.net/instruct...65-INS_WEB.pdf
Print this and measure to make sure you get the same dimensions that are shown.
Old Sep 6, 2012 | 11:05 AM
Gitsum's Avatar
Thanks!
Old Sep 6, 2012 | 01:55 PM
blnewt's Avatar
Originally Posted by TomPeters
Thanks for the quick response.... do you happen to know the dremel part # for these discs or perhaps provide a link to the disc you think you might have used? Could it possibly be this disc?
http://www.dremel.com/en-us/Accessor...l.aspx?pid=420
That would be similar to what I used, I had a multi bit pack from an off brand source that I used but the wheels are about the same.
Old Sep 6, 2012 | 02:26 PM
TomPeters's Avatar
^ Thanks! Over my lunch break I purchased those #420 dremel metal cutting wheels and they worked like a charm. Only used one but these would come in handy for anything metal as it cut through steel with ease. If you want to save yourself some time simply remove the portion of your exhaust that runs by the toe bolt hole. With the exhaust out of the way there is tons of room to use a dremel without the snake vertically with these cutting discs. Hope this helps as if I knew this right away I would have been done yesterday. :-)
Old Sep 6, 2012 | 03:51 PM
blnewt's Avatar
Glad it worked as well for you. Much simpler when you can actually see what you're doing w/ room to spare Also those wheels are about 1/20th the cost of those cut bits
Old Nov 14, 2012 | 06:50 PM
salvador312's Avatar
Originally Posted by salvador312
Go Camber or Go Home!!!!!
I take this back.... :-( I am installing the SPC Camber kit on the rears....
Old Nov 14, 2012 | 06:53 PM
soundmike's Avatar
lol! No sin in doing so, Sal.
Old Nov 14, 2012 | 06:54 PM
hey Mike.... Do you have a DIY on the toe bolt install? I know there is some grinding required.. Is it possible to go back to stock after it's installed... It is actually necessary?
Old Nov 14, 2012 | 09:35 PM
soundmike's Avatar
Here's one from My350z -- http://www.batit.com/forumpics/spctoeboltinstall.pdf
There is no going back, basically if you sell the car, the aftermarket kit needs to go with it.
Depending on how bad your alignment is and how low a drop you have, i think it's necessary, otherwise you'd be almost as limited with the settings as the OEM set-up.
Old Nov 17, 2012 | 09:05 PM
Thanks Mike... Always helpful.. I got the toes within specs on my last alignment.. But with some rear camber.. What do you think? Still need the toe bolts?
Old Nov 17, 2012 | 11:20 PM
soundmike's Avatar
If you plan on bringing camber back to spec, that toe will increase. When you give on one, you take from the other, and vice versa.
Otherwise, those are actually pretty good specs. The toe is a little high, IMHO, but nothing too bad.
R350k5
Oct 1, 2015 08:41 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Crappyday
Jul 28, 2015 04:07 PM
Ninjay16
Jul 20, 2015 01:21 AM
