AC evaporator condensation - how to drain?
Old Jul 13, 2012 | 10:17 AM
Cabrito's Avatar
07 G35S 6MT
When I go around corners or brake I can hear the blower fan contact a pool of water. So I figure my drain tube must be clogged. Any advice? Specifically:
1. If I remove the glove box will I have sufficient access to be able to clear the
clog from above?
2. If I want to approach the other direction, where would I find the outlet underneath the car?
Thanks!
Dan
Old Jul 14, 2012 | 01:27 PM
Cabrito's Avatar
07 G35S 6MT
Finally found where the tube comes out. It is near the front of the passenger door close to the side of the car. The tube end is about 1" up above a circular hole. I catheterized and it all emptied. The blockage was only a few inches into the tube.
That feels a lot better!
Old Jul 14, 2012 | 01:39 PM
kool_yaar's Avatar
^ glad you figured it out, this post should help anyone who has this problem in the future
G35xdriver04
Nov 7, 2015 08:31 PM
yosip1115
16
Sep 28, 2015 04:14 PM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
G35CO
Sep 4, 2015 09:27 AM
