So i sat this earlier this morning in my car ran some errands. It's been about 85-90 degreas here for the past week and I been running my ac more then usual.
After I ran those errands this morning went inside the house for about 30 min got in my car and clucth pedal went straight to the floor after me pressing it just a tiny bit. Turned the car on ( thought that was going to do something) turned over but coudent put it in gear. Immediately turned the car off poped the hood Andy clucth fluid was completely drained.
Now I'm thinking a leak somewhere probably going to fill the fluid and take it to a shop later today.
And I have a big puddle of water yes it's only water underneath my car.
Any input would be greatly appreciated.
Thank you
Thank you
when was the last time you checked the fluid level? If it's been a while, I wouldn't necessarily think it's a leak since fluid level can drop through normal operation.
It's been a while but like my concern is its completely empty like there isn't a drop in there
If that's the case, I would fill it up and monitor for leaks. The water is likely from your AC.
Found the leak. Cant exactly located it but I see it dripping underneath my car. Now my question is my buddy's shop is about 15 mins away. It takes about 5 mins till it finnsly drains. Could I drove my car there and stop and refil on the way without hurting the system. Clutch transmission etc....
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
iTrader Positive Feedback100
iTrader Feedback Score(7)
Liked:185 Times in 160 Posts
its probably a bad slave cylinder which was common on the 07 and early 08s and was covered under voluntary recall by the dealership. if you already had that done call and see if they will look into it again for you else have to get it fixed yourself
Koolyear ur right it was the slave cylinder now I replaced the clucth last year should I call them again just to see if they would replace it or...
And if not I need to buy a new slave clyinder there charging me around 300 for the labor
Just called a dealer gave my vin to the service manger he told me there is no recalls according to my vin number...
Where would be the best place to buy a slave clyinder
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
^ ya try the dealership first maybe they will replace it under the extended voluntary recall seeing the new slave died so quickly but most probably they wont but worth a try.
Labor will be on the high side cause they need to pull the tranny off the engine to replace the slave cyl as its within the housing, imo anything between 200-300 is acceptable but shopping around does not hurt
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
thats not good... PM rick on this forum and see whats the best price he can get you my guess is around maybe $40-60... if you have some extra $$ i recommend getting the Z1 CSC which is much more stronger than the OEM slave for ~100 HERE... FYI these Z1 CSC require some modification to install but come with instructions which should be easy to follow for any shop.
Also one of the most common issues for the slave cyl to go bad is dirty fluid and/or riding the clutch... keep an eye on the clutch fluid
Disclaimer: iv never used the Z1 CSC myself or driven a G with it, this info is just from my research online and it seems most ppl are happy with the switch but do some research of your own before spending the $$ since i cant be held liable
Lol thank you so much for your input going to MSG Rick now. His name is just Rick on the forums ?
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
not a problem, his username is actually rick@perryinfiniti, just click on that name and then you can msg him
Msged Rick waiting on a response found this just browsing.
2007 INFINITI G35 3.5L V6 :
Transmission-Manual : Clutch Slave Cylinder Price
WAGNER Part # SC142503
{#F142503}
3/4" Bore
* Stocked in outlying warehouse--shipping delayed up to 1 business days
$47.79
Add to Cart
SACHS Part # SB60301
Standard (Only 3 Remaining)
$177.79
Add to Cart
It's from rockauto.com
What u guys think ?
{#F142503}
3/4" Bore
$47.79
Add to Cart
$177.79
Add to Cart
What u guys think ?
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
Was the slave cylinder replaced when you did the clutch job last year? If so, I would think there should be a warranty on it. If it's the original though, and it's not included in the recall, then unfortunately it's on you. Originally Posted by Fendi35
Koolyear ur right it was the slave cylinder now I replaced the clucth last year should I call them again just to see if they would replace it or... And if not I need to buy a new slave clyinder there charging me around 300 for the labor
HMMM . . . Re-reading the previous posts made me want to clarify whether the service rep said that the VIN number wasn't included in the recall, or if it had already been performed on that VIN so it wasn't covered again.
