Any G35S sedan runs aggressive alignment with stock suspension and stock 18" sports r
Old Aug 15, 2012 | 05:26 PM
stockae92's Avatar
I wonder if there's any G35S sedan running (more) aggressive alignment with stock suspension and stock 18" sports rims with minimal camber wear on the tires?
Old Aug 15, 2012 | 07:34 PM
pattyballs's Avatar
It sounds like you are asking if anyone is running negative camber / \ with stock suspension and stock wheels........ I hope not lol.
Old Aug 15, 2012 | 08:32 PM
vqsmile's Avatar
Why do you say that, do you just mean as far as looks go?
As far as handling, it's an improvement.
Old Aug 15, 2012 | 09:21 PM
pattyballs's Avatar
I mean i was talking about looks and performance, but i guess its not a bad idea if you can get it into specs that would improve performance without destroying tires in a short period of time lol.
Old Aug 16, 2012 | 12:42 AM
apexi957's Avatar
Stock height still has negative camber, but I don't see the point of running aggressive camber on stock height and wheels. Kind of redundant.
Old Aug 16, 2012 | 01:01 PM
stockae92's Avatar
i guess what i meant wasn't AGGRESSIVE aggressive, but like more -ve camber than OEM spec, and not in a way that would destory the tires.
but i suppose in the long run, if i DD with more -ve camber, it would destory the tires anyway
Old Aug 16, 2012 | 01:12 PM
vqsmile's Avatar
I guess it depends on how you drive. If you're pretty aggressive in turns, then you'll likely wear the tires less if they have a tad more negative camber, which would tend to minimize scrubbing the outsides of the tire. I definitely think there is a happy medium between a conservative stock alignment spec and a full on performance spec. You should be able to pick up a little handling boost without suffering the BMW X5 syndrome.
Old Aug 16, 2012 | 04:06 PM
VMRWheels's Avatar
If this is your DD and you're on OEM suspension I'd probably just keep everything with spec, and invest in some good quality tires for spirited driving.
Jusseth
Sep 13, 2020 12:25 PM
jimNC
Jul 25, 2015 05:47 AM
Thunderaan
Jul 22, 2015 07:40 PM
nascarbuff17
Jul 16, 2015 10:23 AM
