headlight replacement 2007 g35 sedan
Old Aug 27, 2012 | 08:49 AM
mdmccoy2020's Avatar
I need to replace my driver side main headlight and the dealership says it will cost 405.00 to do it!!!can I do it myself? how?
Old Aug 27, 2012 | 09:07 AM
mathnerd88's Avatar
Do you mean the HID bulb? The ballast? The entire headlight? Which one is it? If it is the bulb you can do it yourself easily if you have small hands.
You'll need to replace both bulbs though. You can buy a set form Amazon for less than $100 for two and do them yourself. If you only replace one, you'll have the problem of both bulbs having different colors due to color shifting on older bulbs. Maybe it's time for you to upgrade to the Osram CBI's for $200 a pair (most sought out after HID Bulb.) If not you can buy Philips 85122+ bulbs (also another favorite) or the regular Osram (Sylvania) 66240 HID bulb for less than $100 per pair. The size that fits our cars is D2S.
Replacing the ballast will take more work, and it will cost more since the part itself is around $200 brand new, but you can find that used for around $75 on ebay or so.
Old Aug 27, 2012 | 11:01 AM
It is the xenon bulb in the center, the main headlight buld. Autozone has them for 99.00 a piece, but I do not know how to get into it. It is the drivers side.
mdmccoy2020
Old Aug 27, 2012 | 11:02 AM
It comes on and goes off if that amkes a difference.
MMc
Old Aug 27, 2012 | 02:10 PM
mathnerd88's Avatar
If it comes on and goes off, that suggests more of a ballast issue, not a bulb issue. A dead bulb usually turns pinkish or a different hue is it is going bad...and eventually won't fire at all. If it turns on and then goes out, it sounds like a different issue, most likely the ballast.
What you can do is swap bulbs between your passenger and driver side and see if you get the same problem. If you do, then you will need to change out the ballast. A new ballast will cost a couple hundred dollars.
Like I said before, you would probably need 2 bulbs, unless you don't mind one headlight being a different color or brightness/intensity than the other. Here's a link to Amazon. Philips and Osram are the most respected HID bulb companies in the automative lighting industry.
Philips:
Amazon Amazon
Osram/Sylvania:
Amazon Amazon
The easiest way to change the headlight bulb is to go through the wheel well...you have to take off the wheel well cover (very easy or pry to the side) and then reach in and change the bulb. I'll send you a link how to do so. If you don't want to remove the wheel, you can turn the wheel all the way to the right or left to reach the bulb.
Here it is:
http://www.moodym.com/articles/G-hid-replace.shtml
Old Aug 28, 2012 | 03:26 PM
kra373's Avatar
http://www.theretrofitsource.com/
They're the best. You want the Matsushita ballasts, it's the direct replacement and they might have used ones available.
They also have a wide selection of lamps too
Old Aug 29, 2012 | 06:54 AM
Thanks for all your help it is fantastic. I took it in to a local repair shop who was able to change the light bulb thru the wheel well, but that didn't fix it. They said I needed the ballast which was integrated into the whole headlight assembly that I would have to buy for 1,000.00 plus tax. 1284.00 installed. Do I really have to buy the whole assembly and if so, any suggestions on where I can get it cheaper?
Marcus
Old Aug 29, 2012 | 08:29 AM
mathnerd88's Avatar
http://www.theretrofitsource.com/pro...roducts_id=147
You can buy them new for $170 for two Matsushita ballasts which are a direct fit to our headlights and OEM manufacturer. You can try selling the other used one from your headlight.
The ballast is not integrated into the headlight assembly. You can unscrew them from the headlight itself. Most places will ask you to replace the whole headlight because it is easier than taking it apart to change out the ballast (or they can make more money off you.)
The other reason is that Nissan parts do not sell the individual ballast by itself; they only sell the ballast as part of a whole new headlight.
Old Aug 29, 2012 | 01:01 PM
kra373's Avatar
Mathnerd88 just said the same thing I was about to.
http://www.theretrofitsource.com/product_info.php?products_id=147
You're going to have to remove the bumper cover. Change the ballast and lamps on both sides since you're gonna have the cover off anyway. Plan on taking around three hrs if you haven't done it before. Good luck!
Old Aug 30, 2012 | 10:18 PM
cuerojhon's Avatar
i need help
08 g35 sedan
need to know how many fuses does the headlight have. is it one for both lamps or it is one for each,
Old Aug 30, 2012 | 10:20 PM
cuerojhon's Avatar
also where can i get the rocker panels for a good price
Old Aug 31, 2012 | 12:31 AM
vqsmile's Avatar
Originally Posted by cuerojhon
i need help
08 g35 sedan
Rather than crashing this one, you should start your own thread. Besides being polite, you're more apt to get more and better answers to your problem.
.02
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
R350k5
Oct 1, 2015 08:41 PM
