Iphone 5
Old Sep 25, 2012 | 01:45 AM
  #31
dsgb73's Avatar
Veteran: Navy
^^ kool, you should be able to upgrade to IOS6 now for the 4s, I did it the other day. There are some funky problems that people, including myself, had when we upgraded from 5.1.1. to 6 but it seems all sorted out now. When you do it, pay close attention to your battery life because that old problem seems to have reared its head again for some folks. Luckily I have the case with the built in battery so I can go charge on the go if need be.
Old Sep 25, 2012 | 04:23 PM
  #32
kool_yaar's Avatar
^ thanks for the heads up! but since u say that i think i should wait for a week days and see what results most people get after updating and let apple fix the issue first, i would hate to have the battery life issues again...
Old Sep 25, 2012 | 06:30 PM
  #33
b-dRizZy's Avatar
is not as bad as you will think.. i upgraded my 4 and seems to hold up alright.. not really a issue.
Old Sep 25, 2012 | 08:38 PM
  #34
kool_yaar's Avatar
I just updated it so we'll see.. THIS scares me a bit reading the comments below with so many people having substantial problems but its done now so fingers crossed!
Old Sep 27, 2012 | 03:06 AM
  #35
dsgb73's Avatar
Veteran: Navy
I couldn't call out on mine for about 4 hours after I updated it without having to turn on speaker but after throwing it on the floor it worked, lol. I went to a forum to see what problems people were having and sure enough I wasn't the only one who had that problem. As far as battery life, people are reporting quicker battery drain on there's and I concur. I've watched mine lose power at a much accellerated rate than before flashing to IOS6. I have one of those cases with the built in battery just for safe assurances,
Old Sep 27, 2012 | 08:43 AM
  #36
daniel2288's Avatar
Just ordered this yesterday
Amazon Amazon
Leave this connected to the center console cig lighter and get a cord that turns 3.5mm to red and white plugs. According to the reviews when you start your car up the Bluetooth will turn on and auto connect to your phone. If I ever need to charge my phone and listen I have a usb cigarette adapter that I plug into the ash tray
Old Oct 1, 2012 | 05:21 PM
  #37
wallawee's Avatar
iPhone 5 works with my g35s. fyi.
Old Oct 1, 2012 | 06:32 PM
  #38
dofu's Avatar
20 Year Member
Don't you guys wish they still used Google maps?
Here's a tip for battery life: there is no need to let the battery drain before you charge it up - that actually lowers battery life. Keep your battery above 50% charge. The battery is good for something ridiculous like 100,000 charges with each charge lowering battery life. But if you keep it above 50%, it counts as only one charge no matter how many times you charge it up as far as battery life is concerned. Each time you let it get below 50% or so and charge it, that will count as another charge. And don't let your battery die, it's worse than using a charge. The source of this info are engineers at Apple who personally did the extensive battery life testing.
For those having problems with your battery after upgrading the OS, can't help you there...
Old Oct 1, 2012 | 08:27 PM
  #39
kool_yaar's Avatar
Miss the google maps for sure... while battery consumption has increased, thankfully though its not nearly as bad as hundreds of bad reviews iv read so i guess i should be happy about that
Old Oct 1, 2012 | 08:37 PM
  #40
mrclowny's Avatar
I returned my iPhone 5 today. I'm going to try an Android. . The Samsung Note 2
Old Oct 2, 2012 | 05:39 AM
  #41
Mike45's Avatar
so everything clear it works on the navi screen? like the iphone4 did
Old Oct 2, 2012 | 10:09 AM
  #42
mrclowny's Avatar
Hmmm i wonder how he would know if the adapter/cable isn't available in my area yet.
Old Oct 30, 2012 | 10:27 PM
  #43
highgrovemanor's Avatar
Bumping for any updates? A little more reading indicates the not supported 'iPod out' was to better mimic the iPod interface. Engadget had a BMW/Mini reference to it, but I don't know if its core to our Infiniti support.
So would someone PLEASE verify or debunk? Lots of anxious G35 drivers are waiting!
Old Oct 30, 2012 | 11:29 PM
  #44
Donell_706's Avatar
It works fine. No issues with mine. I have a 2007 G-Coupe sport. The charger can be found at almost any store. All it needs is the USB port.
Old Oct 31, 2012 | 12:45 PM
  #45
dj714's Avatar
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
this would only would only work if the car had a AUX port correct?
