Car swerving to the right, steering wheel to the left?!?
Old Oct 5, 2012 | 09:17 AM
nduncan's Avatar
hi guys i am having the same problem with my 2008 G35 with the pulling to the right also all my tires are brand new but still pulling .... please some one help me
Old Oct 5, 2012 | 11:59 AM
soundmike's Avatar
Originally Posted by vqsmile
If your steering wheel is not centered when you are traveling straight down the road, then whoever did the alignment screwed up. I don't care if they were an 'expert' or a dealership, they screwed up . . Period. As far as pulling to one side, there are numerous possible causes besides alignment (bad tire, over/under-inflated tire, dragging brake, bad wheel bearing, etc.), but given that your alignment was not done properly, my first guess would be to start there.
.02
I am very inclined to agree with VQ on this one. I had the same issue at least twice in the past. It was always alignment related. The last time happened a day right after my routine alignment --- this time it seems mr. alignment professional forgot to tighten the bolts properly. I hit a small dip on the road (hit this every day, so it's not the problem!) and for the rest of the day until i got back to the shop, the steering wheel just kept tilting more and more to the left.
By the time i got to the shop, the wheel was practically at a 45 degree angle while going straight.
Fixed alignment, double-checked bolts and voila. Everything is fixed again. And yes, i still hit that same dip without issue.
Worst-case, your caster is totally off on one side. Sadly that can't be adjusted in OEM-spec.
Old Oct 5, 2012 | 05:50 PM
platinumg35x's Avatar
Thanks for all the replies guys. I think the steering wheel itself is off-centered....I had the whole wheel replaced due to chipping and it seems like it may not have been put on properly. As for the car swerving to the right, I called up the dealership and they said to bring the car back in and they'll take a look at it. I am inclining towards it being something else....as the problem hasn't gone away after 3 alignments at 3 separate shops. Fingers-crossed.
Old Oct 6, 2012 | 07:51 PM
G force's Avatar
That happened to me too. It was off center to begin with, but then when the dealer fixed the chipping paint it was way off. Its a quick adjustment.
chinee
Jun 10, 2024 07:48 PM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
