Help with rims and suspension but warranty issues
What's up g drivers I'm new to the forum and a first time owner of a 08 g35 sedan but I've only had Nissan cars in the past and one 5 series Beemer. Anyways, I just got the car last December and the first thing I wanna do is put rims and suspension but since I have a warranty on the car, if I put suspension on it I've been told it will cause me issues if I have problems with suspension when I bring it to a dealership. So if I can't do that I was wondering what after market rims will look good with a stock height. I do want a decent looking flush fitment, and I know it will look weird with stock height but any suggestions??
To my knowledge the warranty is going to only be voided on the parts you replace. There are plenty of examples of cars that are on stock height with new wheels that look decent, but they definitely look better with a drop!
If you drop the car pretty much anything related to the drop could cause a warranty claim issue. For example you have a strut go bad, or control arm, bushings, or any undercarriage part that may get harmed from being lowered. If a part on your car requires warranty work and has nothing to do w/ your suspension you shouldn't have any problem though.
It really depends on the dealer I think.
So far, I have had the following warranty work done to my car, post-dropping with springs, swapping to 19s, and putting 15mm spacers.
Passenger side vibration, started 2 days after changing my springs. The dealer changed the rack, tightened everything, and the vibration is now minimal.
High pitch squeaking on braking. Changed everything but still persists, possibly caused by the spacers (as it started few weeks after adding the spacers). Dealer checked everything for free.
Suspension creak. The dealer changed the control arm bushings, but didn't touch anywhere around the spring.
rezendvous420
May 31, 2020 01:26 PM
iknowitsfast
Aug 12, 2015 02:08 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
