info on good aftermarket HID kits
Old Nov 16, 2012 | 05:11 AM
nestor626's Avatar
any good hid kits out there i purchased a kit and after 6 months everytime i would hit a bump one of the lights would turn off anybody have any suggestions?
Old Nov 16, 2012 | 03:06 PM
VMRWheels's Avatar
Did you check your ballasts and everything to make sure it had a secure connection?
Old Nov 16, 2012 | 06:04 PM
nestor626's Avatar
yeah o took it to the shop were i got them install numerous times and they said everything was "fine" they even gave me new ones but after a few months same rhing happen
Old Nov 16, 2012 | 06:30 PM
saywat?'s Avatar
maybe gotta put some kind of cushion between the ballast and mounting area
Old Nov 16, 2012 | 08:16 PM
VMRWheels's Avatar
What HID kit at your using OP?
Old Nov 16, 2012 | 10:53 PM
nestor626's Avatar
honestly i just went in there and they did all the job for me so idk :/
Old Nov 17, 2012 | 09:24 PM
salvador312's Avatar
Our cars come with Stock HIDs. Why would change them? All you need is different temp bulbs... What intensity are you running?
POST NUMBER 3,000 .........party....
Old Nov 17, 2012 | 09:52 PM
Texasscout's Avatar
The very early models had Halogen lights. Some replace the fog/high bulbs with HID also.
Old Nov 17, 2012 | 10:02 PM
nestor626's Avatar
yes at first they just changed the ligh bulb to a 8k and then i went to a 6k still did the same thing so idk i took it back to them and they say everything is fine but ones a hit a little bump n of them shuts off :/
Old Nov 17, 2012 | 10:10 PM
Texasscout's Avatar
Yeah, you must have a grounding problem or some sort of loose connection in the ballast.
Old Nov 17, 2012 | 10:13 PM
nestor626's Avatar
so what should.i do take it to the dealer the people.i take it too keep sayin is fine i explain everything to them.n they checked the wiring and everything they even put a relay on it but didnt help
Old Nov 17, 2012 | 10:32 PM
He is driving an 07-08 Sedan... They all come with stock HIDs.. Not need for an aftermarket kit.. all he needed was some good quality 8K bulbs
Old Nov 17, 2012 | 10:44 PM
This is your stock headlight with the stock ballast, don't tell me they replaced the stock ballast with a cheap ballast? Check your headlight and see if they still there.
Old Nov 18, 2012 | 09:53 AM
Texasscout's Avatar
I don't think we are getting the whole picture here.
Old Nov 18, 2012 | 10:11 AM
nestor626's Avatar
to take out the headlights do u have to take out the bimper too?
