*HELP* 08 g35xs 67342 miles
Old Jan 15, 2013 | 07:25 PM
InfiniG08's Avatar
Exclamation *HELP* 08 g35xs 67342 miles
Hello all, my problem is lately since it started dropping into the teen temps, after driving about 2-3 minutes my traction ctrl shuts off with slip, vdc and brake dummie lights illuminated. After looking at the owners manual i found somethin peculiar.....
It states something to the effect of blah blah blah these lights come on from failing exhaust components or aftermarket exhaust ??? Wtf?? ..... So has any one else experienced this exactly and found an easy fix or. Will i have to give the stealership my bank account info
Thanks for the help
Old Jan 15, 2013 | 07:50 PM
InfiniG08's Avatar
Forgot to mention that i have not done any mods yet to my G
Old Jan 15, 2013 | 07:57 PM
AuAltima3.5's Avatar
On the first gen gs this can be related to a bad battery or alternator.
Is the service engine light on?
Old Jan 15, 2013 | 07:58 PM
InfiniG08's Avatar
Negative... Just lights and no trac ctrl.... Batt and alt check perfect on my multimeter
Old Jan 15, 2013 | 09:59 PM
matts08x's Avatar
This is meant in the most helpful of ways (and not sarcastically). But did you try the search function for an answer? I can't imagine that, if it's a very common problem, it hasn't happened to another user on here.
Old Jan 15, 2013 | 11:35 PM
mathnerd88's Avatar
Thanks for the help
Check your brake fluid or your pads? Sounds like a brake problem since all of those are brake related.
Old Jan 16, 2013 | 12:03 AM
kool_yaar's Avatar
^ whs, 99% of the time when all these lights come up while driving its due to low brake fluid which is due to low brake pad life
Old Jan 16, 2013 | 11:46 PM
InfiniG08's Avatar
Ahhh hah.... Brake fluid somehow escaped me when i did ALL my fluids last month..lol
Cant believe i forgot the most important one doh!!! Lights have not come on all day
Thanks gents!!!
Old Jan 17, 2013 | 01:13 AM
yarrh's Avatar
when mine were worn, i would get the same lights whenever the car was on a slope or when it accelerated rough. the low fluid level swishing around under such conditions sets them off.
instead of just topping off the brake fluid you should inspect the pads. you're likely due for a new pair.
topping it off, you will have excess when you actually replace the pads
Old Jan 17, 2013 | 09:44 PM
vqsmile's Avatar
Originally Posted by yarrh
...instead of just topping off the brake fluid you should inspect the pads. you're likely due for a new pair.
Ahh, go ahead. It's really not much of a problem to remove a small amount of fluid with a simple baster when you redo the brakes; and especially since I got at least another 15K miles out of my brakes before needing replacement (after I had topped the fluid off). Besides that, and more than likely, your fluid could use a thorough changing by the end of a set of brakes anyway.
Old Jan 19, 2013 | 08:53 PM
InfiniG08's Avatar
Checked my pads today and lookes about time to do pads... So i bought akebono's front and rear and will change out the fluid.... Thanks for all your help!!
Old Jan 30, 2013 | 07:45 PM
Supremee's Avatar
Thank god for Kool_yaar. Idk how you explain this stuff all the time.
Search guys search! Looks like you resolved your problem. Good luck on the car
chinee
Jun 10, 2024 07:48 PM
Mac8008
Aug 4, 2015 09:19 PM
Terry_G35
Aug 4, 2015 02:38 PM
socalg35x
Jul 28, 2015 10:42 AM
rping
Jul 26, 2015 09:53 PM
