Engine not starting (battery is fine)
Old Jan 25, 2013 | 02:25 PM
lefizzet's Avatar
I just tried starting my car and it sounds like it turns over for maybe half a second then just dies down. I don't know if this has to do with it but I accidentally sat on the alarm button so while the alarm was still going off I pressed the brake and tried starting the car but then it just died down, now it won't start whatsoever. It's also relatively cold so that may be a part of it but I doubt it since I've been driving it fine the past couple of days below freezing.
Old Jan 25, 2013 | 02:30 PM
dexthurr21's Avatar
have you tried jumpstarting it?
Old Jan 25, 2013 | 02:36 PM
lefizzet's Avatar
Not yet, waiting for my friend to get back w cables. But I figured the battery wouldn't be the problem since everything else works fine, unless I'm mistaken.
Old Jan 25, 2013 | 02:56 PM
terrycs's Avatar
You battery is dying. Have it checked out. It might have enough power to open up the doors, but maybe not enough to crank it. That's how mine died.
Old Jan 25, 2013 | 05:38 PM
hyukki's Avatar
I second this. Mine did a similar thing when my battery was dying. Been fine since I topped off the battery after jump starting.
Old Jan 25, 2013 | 05:39 PM
kool_yaar's Avatar
^ whs while the battery seems to work fine for other electronics it just doesnt have enough juice to start they car i had same issue when mine died
Old Jan 25, 2013 | 07:26 PM
vqsmile's Avatar
Yep, yep. Since the starter function is "by wire", it is electronically controlled by the ecu (not a physical keyswitch) which, if it determines there is insufficient voltage/amperage to function the starter properly, will abort the attempt.
Old Jan 26, 2013 | 01:53 PM
lefizzet's Avatar
That seems to be the problem, thanks guys. Had to jump start my car this morning again for the initial start. Any recommendations on good batteries?
Old Jan 26, 2013 | 02:10 PM
vqsmile's Avatar
For the price, quality, and warranty, I'd go with Costco, but AutoZone's Duralast Gold is similar for slightly more money.
Old Jan 26, 2013 | 07:58 PM
mathnerd88's Avatar
I had the Costco's Kirkland Battery for over a year now. I had it tested last week and it was still good. Can't beat the price and warranty with the Costco batteries.
Old Jan 26, 2013 | 08:32 PM
joedaddy1's Avatar
4th year on costco batteries... kinda slow starting when it's below freezing this winter.. but still good...
i might replace it before next winter though.. can't take the risk.. haha.
Old Jan 27, 2013 | 04:22 AM
terrycs's Avatar
Ditto. Costco battery in my car too.
Old Jan 27, 2013 | 11:52 AM
princealyy's Avatar
incase there is no costco around, or you dont have a membership, Sam's batteries are nice too, and their warranty is great as well.
Had one in my honda, took it in, replaced under warranty for $6 (damn honda goes through batteries every 2 years, no matter what brand, but if that is the biggest problem I have, I'll take it)
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
JMSABO
Aug 4, 2015 11:58 AM
