Passenger Air Bag Sensor Glitch? (Dash and Light different)
Old Apr 1, 2013 | 09:55 AM
Eug96's Avatar
Recently, on the right side of my on board dash has been illuminated with the airbag light flashing repeatedly. The "Passenger Air Bag Sensor" light that is located underneath the climate controls works fine. Illuminates when a passenger is not present and turns off when a passenger is present. Should I be concerned that these lights are not in sync. Is this ? Possibly a driver airbag problem?
Please chime in!
Thanks
Old Apr 1, 2013 | 11:54 AM
mathnerd88's Avatar
You should get that checked out...that is very dangerous and means that the airbag will probably not deploy or deploy prematurely. Any type of airbag sensor malfunction will show up on your dashboard, which is what you're seeing. It may be possible that your airbag has malfunctioned.
Old Apr 1, 2013 | 12:09 PM
vqsmile's Avatar
There are diagnostics that the dealer can run with their equipment (Consult III) to see what the system is complaining about. It may be worth it to have them troubleshoot it, and then decide if you want them to perform the actual repairs or perhaps DIY.
Was your car ever in an accident?
Muski_G
Dec 1, 2023 11:11 AM
wonderizm
Sep 24, 2015 03:09 AM
ZacDesu
Jul 14, 2015 11:13 PM
