NEW TO G35Driver, 60K maintenance & other things?
So im at 62,000 miles on my 2007 VQ35HR
This is what im changing am I missing anything?
Oil & Filter
Tranny fluids & filter
Coolant
In Cabin Air Filter
new 245/25/20... mine are BALD not gonna make it to cali- im moving from seattle
Rotors (20" wheels caused some warping it feels like) OEM for now til Brembo upgrade
Brakes
What else am i missing?
Oil & Filter
Coolant
In Cabin Air Filter
Brakes
Oil & Filter
In Cabin Air Filter
Brakes
Oil & Filter
In Cabin Air Filter
Brakes
power steering fluid
engine air filters
differential oil
top off battery cells with distilled water
some go for the serpentine belt then too.
EDIT: BTW, there isn't a filter to change on the tranny, and unless there's some particular concern or the fluid looks really cooked, it's usually just a drain and fill of the pan (about 4-5 quarts +/- ), but be sure to use the Nissan "Matic-S" fluid. The trans in these cars really is quite sensitive to generic fluids and using them could very well mess up your tranny. Also, these brakes are prone to judder, which is akin to what most people call warping, so it most likely isn't caused by your wheels.
Ah fresh blood, welcome to DRIVER! The 60K mile service includes all fluids/filters and belts if they show any signs of wear. Warped rotors are a PIA if bad enough, the cause is allowing your tires/wheels to be installed using a impact gun. Installers don't know when to quit and will frequently over tighten your lug nuts....rotor warp! Let them know you want installer to use a torque wrench set at 85, issue solved! Dealerships have a machine that will true your rotors while on the car, cost is minimal and will make the trip south more enjoyable!
Good Luck....Gary
Good Luck....Gary
WELL MOST OF THESE I FEEL SAFE DOING MYSELF, except rotor turn.
unless the dealer gives me a good deal! trying to be cost effective for the move!
thanks for the welcome, I have big plans for the v36
Not to contradict Gary, and maybe it's different for the V35 models, but these V36 sedans just came with some pretty poor rotors (and pads). They tend toward judder regarless of lugnut torquing (although his comment is generally accurate), and if you read up a bit, you'll most likely find that most people here have had the judder return again after they had them turned. You can do it to anyway just to squeeze some more life out of them since you plan to upgrade eventually anyway.
Good Luck....Gary
Good Luck....Gary
infinitiway
Aug 8, 2017 12:38 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
DRG35R
Sep 16, 2015 05:33 AM
