front and rear camber kit
Old May 25, 2013 | 12:55 PM
OGsedan35's Avatar
Will I need both front and rear? Or just the back will be ok?
I might just purchase some coilovers first and just drop my car on those and save up for the kit later. But I just need to know what will I need. And will eBay coilovers be good, they are name brands on there and go for $800-900, and that's not bad.
Old May 25, 2013 | 11:22 PM
blnewt's Avatar
My Megan Street Series Coils and the similar BC Coilovers will drop the back of your G to just about zero gap at the highest setting, so you will need rear camber & toe kits if you go w/ either of those coilover sets. Not sure what other low priced coils minimum drop would be, so can't comment on them. If you get coils that will keep your G only an inch or a bit lower at their highest setting then you could get the coils first then get the kit if you decide to go lower at a later date.
Old May 26, 2013 | 10:46 PM
bluedevils95's Avatar
If you drop your car more then a inch you will need a camber kit. if your local i can sell you my front camber
Old May 26, 2013 | 11:32 PM
gary c's Avatar
Unless you're partners in a tire store here's the smart way to lower your car, buy BC coilovers (worth every dime) don't install until you can afford a camber kit (SPL will get you back to OE specs) Once you have everything together then install the coilovers and camber kit along with a 4 wheel alignment. Doing it this way you haven't wasted a set of tires which is worth $800 to $1,500. Oh, stay the hell away from ebay trash they're not worth the headaches! Quality in what you buy is worth every dime when you're doing suspension mods....Gary
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
