Car Overheated and Went Into Limp Mode - Clueless
Old Jun 18, 2013 | 07:20 PM
vqsmile's Avatar
Originally Posted by Timbits93
As it stands, they said its the thermostat that needs replacing. ...
fingers crossed that that is all
Old Jun 18, 2013 | 09:34 PM
Timbits93's Avatar
Just picked it up. Wasn't able to talk to any of the Service people since they were closed.
However what i paid for the resistor does stand as a service credit. So the repair was free. Replaced the thermostat and lower hose due to leaking, also bled the cooling system.
Went for a bit of a drive again, this time the temperatures remained just slightly below the middle like how it normally is.
Old Jun 18, 2013 | 10:08 PM
vqsmile's Avatar
** not exhaling until you put some hours on it **
(although it sounds very promising)
Old Jun 19, 2013 | 05:48 AM
dsgb73's Avatar
Veteran: Navy
Hope it all works out for you, like vqsmile said put some more mileage on it and report back please.
Old Jun 28, 2013 | 10:42 PM
Timbits93's Avatar
I put about 300km on it so far in the last 2 weeks.
Temperatures are all good!
However drove it this evening and the Service Engine Soon light came on while driving... car drives fine and temperatures are all good. Now that is a mystery. Filled up on the weekend but if its the gas cap, should have lit up a couple days ago.
Another mystery to solve... once again!
Old Jun 29, 2013 | 12:31 AM
vqsmile's Avatar
Codes man, we need the codes!
Old Jun 29, 2013 | 01:06 AM
Timbits93's Avatar
Either buying an OBDII scanner for $59.99 tomorrow or just see if the dealer is willing to pull the code for free after all that's happened.
Least it isn't in limp mode!
Old Jun 29, 2013 | 12:19 PM
Timbits93's Avatar
Bought a code reader. Came up with two codes.
P0420 - Catalyst System Efficiency Below Threshold Bank 1 - Freeze Frame Data
P0081 - Intake Valve Control Solenoid Circuit Bank 2 - Pending
Freeze Frame Data for P0420 pulled from the tool
Old Jun 29, 2013 | 08:18 PM
vqsmile's Avatar
Hmm, at first glance the P0420 looks like a bad cat or O2 sensor, but the fact that you have a pending p0081 gives me some pause to consider whether the issue with the valve timing is causing the issues with the emissions . . . but then it wouldn't make sense that the problem cat is on bank 1 and the valve timing solenoid issue is on bank 2. I prefer to think things are usually connected and relevant, but I guess I'm not seeing it with this one
I guess I would though, want to make sure neither are connected with recent events for the car (but I suspect they are). It Is possible that when the dealer worked on it for either fluid swap or later repair for the overheat, they could have inadvertently disconnected (or even damaged) the connection to the VVT solenoid, so it's worth a shot seeing if something is amiss there.
Then it also occurs to me that if they swapped your tranny, they probably manhandled the cat as well (cats and O2 sensors are rather delicate), as I'm fairly sure the exhaust gets removed during a tranny swap. I think you may want to revisit the dealer, express your serious concerns with all the issues you have been having AFTER they worked on it, and then I'd even suggest you might want to consider do it LOUDLY. Sometimes, this is what it takes to get them out of the "Sure, we'll fix anything, but you're paying for it" mode.
http://engine-codes.com/p0420_infiniti.html
http://engine-codes.com/p0081_infiniti.html
EDIT: Just to be clear, you had your coolant services at the dealership, right? (ie. You didn't do that yourself)
Old Jun 29, 2013 | 08:59 PM
Timbits93's Avatar
Yeah had my coolant services at the dealership.
But yeah exactly, the car was pretty much fine until they swapped the tranny - then all these things started to crop up.
I scheduled an appointment Tuesday morning actually (Monday is a holiday). Will see what they say about it this time.
Old Jun 29, 2013 | 10:11 PM
vqsmile's Avatar
That's really sad.
On the one hand, you hate to go back to the dealer that likely screwed up in the first, yet you pretty much have to if you want to have a chance at their covering it. I wish you the best in negotiating with them. Perhaps they will redeem themselves by at least owning up to their mistakes.
Old Jul 2, 2013 | 01:48 PM
Timbits93's Avatar
Update... again.
Just wanted to let you guys know of an update.
They're going to replace the catalytic converter once the part arrives. The P0420 code occured on 10 occassions apparently all at about the same speed (refer to the freeze frame data).
Also regarding the P0081 code, they told me they won't touch the valve timing until they can read the computer again when the car comes in or if the check engine light comes back on. They dont want to do anything about it yet since it would be a 2-3 day job apparently. But they will replace it if requested.
Btw, all of this is covered under warranty. But its just so time consuming.
So will report back.
Old Jul 3, 2013 | 05:29 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry to hear about all of your issues but I'm glad to see the dealer working with you to get them resolved. That's a win in itself.
Hasanbaloch
Feb 29, 2024 08:45 PM
hdmark
Apr 29, 2019 04:31 PM
yassy
Aug 3, 2015 12:24 AM
newg37
Jul 26, 2015 09:32 AM
Cskeet
Jul 21, 2015 05:48 PM
