center console side dash near glove box falling apart.Glue recommendations? pic
Old Jul 23, 2013 | 05:13 PM
trulegend's Avatar
Exclamation center console side dash near glove box falling apart.Glue recommendations? pic
i have a 2007 g sedan 6mt, i am noticing the center console side panel is starting to come out. Last week i did the cabin filter change since then it seems its falling apart.
I was looking at previous owners records and it appears he has had this issue in the past but on the instrument cluster, which infiniti replaced under warranty. I no longer have warranty, can someone recommend what i should do to stick that piece back in??
Here are some pics as to which piece is sticking out.
center console side dash near glove box falling apart.Glue recommendations? pic-fcvui4a.jpg
Old Jul 23, 2013 | 07:17 PM
muyrec's Avatar
Don't bother just buy another new one. i tried to fix that part along with the instrumental panel shroud. It just wouldn't stick. the passenger side is holding out fine but the driver side you can see the edge of the rubber popping out. Those panels cost around $40 last time i checked.
Old Jul 24, 2013 | 02:50 PM
trulegend's Avatar
whats involved in replacing them? do i have to remove the glove box? where should i start to look?
Old Jul 24, 2013 | 02:51 PM
trulegend's Avatar
what type of glue did you use on the passenger side? to stick in?
Old Jul 24, 2013 | 06:57 PM
muyrec's Avatar
http://www.homedepot.com/p/3M-24-oz-...e-80/100174709
Old Jul 26, 2013 | 05:41 PM
terrycs's Avatar
Infiniti knows about this issue because the new panels are no longer padded and just a thin piece of plastic now. I had to change both sides on mine too.
Getting new ones will be better in the long run.
You'll need to remove the rear panel of your glove box too.
Old Jul 26, 2013 | 07:42 PM
trulegend's Avatar
thx you for the info?
how much did it end up costing you?
Old Jul 27, 2013 | 12:34 PM
terrycs's Avatar
I did mine in June 2012. Back then, I paid $67 for each side.
Part numbers are:
68134-INF6A
68135-INF6A
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
wonderizm
Sep 24, 2015 03:09 AM
vstypicals
Jul 20, 2015 10:55 PM
