Cause for the dreaded P0011/P0021 codes that everyone is curious about
Old Nov 2, 2014 | 02:11 PM
  #196
cjake39's Avatar
Not sure where else the contamination would be. I even changed out the small micron filters and the oil pick up was clean.
Old Nov 2, 2014 | 02:12 PM
  #197
cjake39's Avatar
I also blew low pressure air in all the holes to ensure they passed through.
Old Nov 2, 2014 | 02:22 PM
  #198
vqsmile's Avatar
I think this was the post I was remembering:
https://g35driver.com/forums/g35-sed...ml#post6934796
Old Nov 2, 2014 | 02:38 PM
  #199
cjake39's Avatar
Not really sure
How to check that though? My scan tool shows timing is adjusting from 10 to about 40 going through the rpm
Old Nov 2, 2014 | 09:55 PM
  #200
vqsmile's Avatar
^^ I was also wondering if there's any relearn procedures that you might need to do.
Old Nov 6, 2014 | 06:21 PM
  #201
vqsmile's Avatar
Just in case there is any confusion or any doubters left among us regarding whether or not the new oil gallery gaskets are truly different now (i.e. specifically metal reinforced VS. paper material) . . .
I bit the bullet and purchased the smaller one for a whopping $4.25 w/tax and proceeded to dissect it. The larger one is made of the same material as this one, but it cost $21 and I'm too cheap for that.
Scraped away the coating down to the solid metal substrate.
The razor would not even cut through the metal. I had to use some good utility scissors.
And if you're still not convinced, here's the old magnet test:
SO, these new gaskets will definitely not be blowing out like the old ones.
Once again, the part numbers for these are: 13533-JK21A (the larger one) and 13533-JK21B (this smaller one).
Old Nov 9, 2014 | 12:33 AM
  #202
Triton3.5's Avatar
Outstanding!! thanks for showing!!! all this....
Old Nov 10, 2014 | 01:56 PM
  #203
Robbie Zahoran's Avatar
P0011 / P0021 codes Jason
Originally Posted by infinitidude
I have seen numerous amounts of these cars come in with the dreaded P0011/P0021 intake timing control codes and I have read numerous posts of how nobody knows the answer. I have repaired a bunch of these and it is indeed an oil pressure issue and not a sensor problem. When the front timing cover is removed you will see 2 caps held to the rear timing cover with phillips head screws. The paper gasket gets blown out and it blows oil right into the timing cover and causes pressure drop to the intake timing solenoids. There is an updated gasket that has metal inside the gasket to keep it from blowing apart like the paper gasket seen in images. This is why the codes keep coming back no matter what oil flushes and sensors are replaced. Hope this helps you guys.
I have these codes along with oil burning slowly a quart a week, and if I step on the gas hard, a cloud of smoke comes out the tail pipe, the dealership says I need a new block, or piston rings.
Thanks.
Old Nov 10, 2014 | 01:57 PM
  #204
I have an 03 Infiniti G35 Coupe
Old Nov 10, 2014 | 05:03 PM
  #205
takeapieandrun's Avatar
The first gen can have oil consumption issues, however this thread is discussing the V36 (second gen), and oil pressure issues caused by this particular gasket.
Old Nov 13, 2014 | 12:25 AM
  #206
mathnerd88's Avatar
My 07 G35x sedan is nearing 90k miles, but I was wondering if this could be the cause of engine vibration at idle while in gear. (Mine stays at around 600rpm.) I noticed that the vibration isn't constant, but it is in rhythm. My whole car vibrates and I can even see my HIDs vibrating against the wall.
Sometimes, the engine sounds like it won't start when I first try to start the engine. It sounds like it is very weak for the first couple milliseconds as it is starting but then turn over normally afterwards. My battery isn't bad and has been tested to be good.
I have no check engine lights or anything. Can these issues be due to low oil pressure in the valves caused by the blown gasket? My engine doesn't seem to be running very healthy.
The engine is still smooth while in motion and the transmission is still shifting fine. I've been doing oil changes every 5k miles with Mobil 1, and the oil levels are fine and no oil consumption. I also have no noticeable loss in power.
I know the only confirmed diagnosis is to hook up an oil pressure gauge, but I was hoping if anyone can have insight on this. I feel like if I have to pay thousands to fix this problem then I should probably trade my car in before the check engine light comes on.
Old Nov 13, 2014 | 12:47 AM
  #207
vqsmile's Avatar
Dunno
Lots of things can cause vibration, especially if the car is in gear, but if your car is truly idling at 600 instead of 650+, that alone could cause a bit more vibration since it is rather low. You know my opinion though: running fine or not, EVERYONE should have their oil pressure checked just so they know where they stand.
I'd actually love for a dozen or so people on this forum (aka: pretty much EVERYONE who actively posts anymore ) to check their OP and report back here. Who knows?... Maybe my case was just a total fluke that doesn't bear out in any numbers. Only a bigger sample will tell.
Old Nov 13, 2014 | 12:50 AM
  #208
mathnerd88's Avatar
Originally Posted by vqsmile
Dunno
Next time when I'm doing an oil change with my local mechanic, I will ask him to check oil pressure at idle.
Sorry if this has been answered before, but what should be the oil pressure at idle and at 2k rpm?
Old Nov 13, 2014 | 01:14 AM
  #209
vqsmile's Avatar
650 rpm => 14 psi or more
2K rpm => 43 psi or more
Note: Oil temp =/= coolant temps, and this spec is listed for an oil temp of 176*, which is a temp that will pretty much only occur briefly during late warmup or again following a short shutdown period after having been fully warmed up. I covered this a bit more in the thread I made on checking your OP.
Old Nov 18, 2014 | 10:08 PM
  #210
vqsmile's Avatar
Originally Posted by treacherous
I know I could simply do this myself but am going to a local & extremely reputable Nissan & Infiniti performance shop and have them run the oil pressure test on my car. If it still comes back as good I will try again in the fall of '15 as my warranty expires in 2/16. Worst case I am out a couple hundred for shop time.
Bahaha, I JUST posted in the other thread that this is what I'd do if I were you. Good plan!
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
