Did the dealership get one over on me?
Old Jan 21, 2014 | 09:21 AM
willdogs's Avatar
So i took my car in to resolve a frozen brake issue yesterday on my rear wheel. They stated the caliper was indeed frozen shut and needed replacement and would be covered under my elite extended warranty. I asked if the new pads and rotor would also be covered since the damaged caliper caused them to go bad and they said no. I ended up paying out of pocket for rear pads and rotors to the tune of $520+.
Should the rotor and pads been covered? I know normally it is not since they are wear and tear items, but in the case a malfunctioning caliper caused the damage.
Thoughts?
Old Jan 21, 2014 | 10:01 AM
Finnkc's Avatar
Parts only? one OEM 12.1" rotor and pads - $520 USD?
Old Jan 21, 2014 | 10:04 AM
Urbanengineer's Avatar
I'm fairly certain elite covers parts and labor. But always check around to see if it's a reasonable price... I wouldn't pay more then 500$ for all rotors and pads!!!
Old Jan 21, 2014 | 10:06 AM
willdogs's Avatar
No I preferred to do both rears so that there was symmetry and I didn't have one side with brand new hardware and the other side with old hardware.
2 x Rear Rotors
2 x New Pads
2 x New Clips (apparently the ones I had were damaged/missing)
and Labor
$520
I was willing to pay half to complete one side but the side with the damaged caliper I'm thinking should have been covered.
Old Jan 21, 2014 | 10:21 AM
Finnkc's Avatar
Seems high considering you are under coverage.
Old Jan 21, 2014 | 10:22 AM
willdogs's Avatar
Well I expected to overpay for parts and labor considering its a dealership. I just wonder if they should have covered pads and rotor for the side with damaged caliper which was covered.
Old Jan 21, 2014 | 11:41 AM
PAIXAO's Avatar
Possibly depends on the dealership. I had pads and rotors covered when my caliper seized, but only for the one side.
Old Jan 21, 2014 | 11:48 AM
My local dealership said 66$ brake pad each side, 115$ each brake rotor one side. ~360 for parts and 90$ an hour for labor puts us at 540$. You aren't getting any discount with your warrantee is what I'm seeing.
Old Jan 21, 2014 | 12:06 PM
joedaddy1's Avatar
sounds about right for a dealer/OEM...
kinda sucks on the timing/pricing, but at least you should be trouble-free back there for another 3 years or so...
Old Jan 21, 2014 | 12:07 PM
joedaddy1's Avatar
he's in NY.. major city dealer labor prices are $120 to $160/hr..
Old Jan 21, 2014 | 12:48 PM
GR6RR's Avatar
have them replace the caliper under warranty... drive home cautiously and replace the rotors and pads on your own. You'll save some money...
Old Jan 21, 2014 | 01:14 PM
ttv36's Avatar
Technically I don't think the rotors and pads would be covered under warranty even though the caliper caused the issue since they are "wear" items. Typically I would think the stealership to be nice enough to replace though..
Assuming a non akebono setup the rear rotors should be about $100 for two and $40 for pads (pricing for centric rotors and pads). If they were replacing the caliper it shouldn't have taken more than 15 min to replace the rotor and pads at the same time. So you basically paid near $400 for the labor of replacing one corner.
Old Jan 25, 2014 | 09:39 AM
xcelocity's Avatar
$520 seems about right for stealership prices. I wouldn't say you got taken anymore than any of us would when we go to the dealer.
Old Jan 25, 2014 | 09:55 AM
gary c's Avatar
Yea, you got screwed by the "Stealership" but under the circumstances you didn't have much choice! Brakes aren't normally covered under warranty!
Gary
Marlin84
Apr 1, 2020 12:52 PM
ChrisAult2004
Sep 11, 2015 10:33 PM
Dmill86
Sep 6, 2015 08:14 PM
UT G35
Sep 3, 2015 03:58 PM
nightowl.czc
SouthEast
Aug 28, 2015 08:36 PM
