So this started happening to my interior... with pic.
Old Feb 19, 2014 | 02:44 PM
MikeJones916's Avatar
Originally Posted by WhosUrBuddiee
Very common. The G37 has a TSB for same thing around instrument cluster. The only way to repair it is to replace it.
Would you happen to know the TSB on that one?
Old Feb 26, 2014 | 12:43 PM
So my attempt to fix this issue was met with (expected) sub-par results. The double sided tape was fairly easy to use, and does hold strong, but the panel is so warped that after a day or so it pulled away again, not quite as bad as before, but still not good.
Anywho, this website sells parts, but I am not fully sure if this is the part I am looking for.
http://www.infinitipartsusa.com/v/vs...es/3841285.gif
Is #9 the item I would want to purchase if I needed to replace?
Anyone have any ideas before I go buy a whole new piece?
_Michael
Old Feb 26, 2014 | 11:40 PM
muyrec's Avatar
yeap its item 9.
Old Feb 27, 2014 | 02:55 PM
aktif8's Avatar
_Michael
how much is a new one? I may actually have an extra I can sell you.
Old Feb 27, 2014 | 03:58 PM
That website has the best price and they want $62 dollars for it.
How do you have an extra one, and is it the passenger side?
Old Feb 27, 2014 | 04:11 PM
aktif8's Avatar
I did almost a full g37 interior conversion (console, nav, door panels, etc - I bought nearly a complete 37 interior to this, and have some leftover pieces.) These panels are the same between the 37 and the 35, so I may have the extras laying around - I'll check!
Old Feb 28, 2014 | 10:34 AM
mishmosh's Avatar
Does this just warp over time? Do you guys leave your cars out in the sun alot? Just curious.
Old Feb 28, 2014 | 11:56 AM
Hey Aktif, I am definitely interested.
Let me know if you can find a pic of that panel, also, I would love to see some pics of your conversion as well!
_Michael
Old Feb 28, 2014 | 11:59 AM
Mishmosh, I park in the sun all the time in hot Cali, so have all the previous owners for the last 7 years, and yes, to me it looks like it will just happen.
The design flaw is that the piece in question here hooks in the back, but not in the front where it peeled back.
The slightest amount of warping in or out will pull that piece back so I feel like its hit or miss. My drivers side shows NO signs of warping, while the passenger side went from normal (Infiniti never really lines things up that well to begin with) to what you see there in like 5 days, and this happened here in winter, so there is no rhyme or reason to it.
Old Mar 5, 2014 | 12:25 PM
Aktif, do you have that passenger panel for sale still?
Old Mar 7, 2014 | 02:53 AM
Phalanx's Avatar
Originally Posted by Phalanx
First of all, lets me warn you. I have not tried this on my car so don't blame me if you get in trouble. If you are all out of solution, you may try this method which is used to bend and shape plastic.
1) Heat up the plastic piece using focused sun ray or even an oven until you feel it is flexible enough to bend/shape it.
2) Bend/shape the plastic piece to the desire shape and secure it.
3) Blow cool air (not cold) to the area that you want it to be reshaped. If you let it cool by itself, you won't get it reshaped to what you want.
You may have to redo the process more than 1 time to get to the shape that you want.
Do this at your own risk!
Good luck.
Hey Mike,
Before you put on the new panel, can you try the method above? I just want to see how it turns out on Infiniti interior parts.
Old Mar 7, 2014 | 12:43 PM
Hey Mike,
I am willing to try anything.
My only problem is, I am not sure how the panel actually comes off.
Does anyone know?
Old Mar 10, 2014 | 04:36 PM
b-dRizZy's Avatar
my cluster one top pice pop out on me also so now i know its warped uhg!!
thought this whole time was the clips got loose gess not.
Old Mar 12, 2014 | 02:55 PM
terrycs's Avatar
Just replace the panels:
https://g35driver.com/forums/g35-sed...tions-pic.html
Old Mar 12, 2014 | 02:59 PM
  #30
terrycs's Avatar
The panels don't warp. They factory ones are padded and the glue is coming undone allowing the padding is coming loose.
Replacement panels are not padded and will not become "unglued" anymore.
