So this started happening to my interior... with pic.
Old Mar 12, 2014 | 03:00 PM
  #31
terrycs's Avatar
Originally Posted by MikeJones916
I am willing to try anything.
My only problem is, I am not sure how the panel actually comes off.
Does anyone know?
Glove box will have to come out.
Old Mar 12, 2014 | 03:14 PM
  #32
Urbanengineer's Avatar
Well you haven't been around in a while... Thanks for the info, ill use this to fix my dads car.
Old Mar 16, 2014 | 04:51 PM
  #33
tnduc's Avatar
I had the same issue and just smacked it with the palm of my hand. This pushed it back into place and it has not popped out again.
Old Mar 17, 2014 | 11:41 AM
  #34
MikeJones916's Avatar
Hey all.
So I "fixed" the issue, and the reason for the hesitation in saying fixed is that only time will tell if it actually took.
So what I ended up doing was buying this:
Amazon.com: Permatex 84101 PermaPoxy 5 Minute General Purpose Epoxy, 0.84 oz.: Automotive Amazon.com: Permatex 84101 PermaPoxy 5 Minute General Purpose Epoxy, 0.84 oz.: Automotive
It got great reviews and was very easy to use.
I took the panel out of my car, this required me to remove the glove box which is not difficult, especially since I had done this before when I installed my subwoofer (also a great time to change your cabin filter if need be).
I took some sandpaper and scuffed the hell out of the inside of the plastic panel and then cleaned it all with alcohol. Then I mixed about 1/4 of the epoxy together for about 3 minutes until the stuff got super viscous.
Then, using a flathead screwdriver, I plopped the epoxy down into the gap and made sure I covered all visible surfaces in there, both on the padding and on the plastic, then I took a c-clamp and locked down the middle of the panel to itself, then took hard bread clips and grabbed all the side pieces of it.
I let the panel sit for 4 hours in my warm garage. Only a tiny bit of the epoxy leaked out of one side and after 10 minutes it was as hard as a rock. I was able to pick of any excess very easily.
Re-installed panel with no issues and it lines up great, there is no smell whatsoever to the interior of my car and I can feel that the panel is hard. I still have a very small light crease in the panel where it peeled back but it really isn't noticeable. After a good coat of meguiar's it looks almost flawless.
Like I said, only time will tell on this one, the odd thing about this cheap Nissan part is that the panel had a padded back, and that padded back is what peeled away from the plastic panel that it lines up to, but there was no glue remnant or anything so I am really not sure how it was ever attached.
Anyways, if you never hear from me on this thread again, the epoxy held, if so it will be me buying that $60 dollar part and replacing it.
Old Oct 26, 2014 | 09:17 PM
  #35
So if any one cares, the update is that the glue has held up, but the panel peeled off from other spots and I know now that it just needs to be replaced.
I am curious though, from the pic I showed on this thread, what color would you consider that panel?
I would say... black. However, when I look on this website the two color options are "wheat" and "graphite/stone" and I don't know if that is the only two colors.
Any thoughts?
Old Oct 26, 2014 | 09:49 PM
  #36
takeapieandrun's Avatar
I'm pretty sure the black interior is called graphite.
Old Nov 1, 2014 | 08:34 PM
  #37
Yeah I would have to agree with you.
Does anyone know for sure on this? Has anyone purchased something in this color and had it match the normal black on the interior?
_Michael
Old Nov 1, 2014 | 11:46 PM
  #38
goalomeri's Avatar
Yup you can go with Graphite, i bought paddle shifters and Graphite was my black interior color.
Old Nov 2, 2014 | 01:43 AM
  #39
vqsmile's Avatar
_Michael
I always just assumed the dark color was Graphite, but now you actually have me wondering if they might have tweaked it just a bit for a better contrast on the cars with the Wheat interior.
I'd suggest you speak with a knowledgeable parts tech to verify. If you give them your vin they can always tell you what you need.
Old Nov 2, 2014 | 08:03 AM
  #40
Texasscout's Avatar
You could always use a nice big self drilling/self tapping screw through the piece and into the trans tunnel, don't think that would ever come back up. Then a little black paint on the head.
chinee
Jun 10, 2024 07:48 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
Frostbite91
Aug 20, 2015 07:20 PM
chinee
Aug 8, 2015 10:11 AM
JMSABO
Aug 4, 2015 11:58 AM
