Weird Closed/Open Loop Issue
Old Mar 11, 2014 | 05:13 PM
IPL_G35s's Avatar
Overall Summary : The car stays in open loop (hot). For instance when coming to a red light from ~40mph the RPMS when clutch is disengaged jumps to 1500RPM then back down to clean idle speed 800. Only when warm/hot.
I have Uprev ( Pro ) aka I have the cable and can do my own tune.
I can do the throttle/pedal/idle relearn/exhaust cam relearn/AF relearn until my head turns blue but nothing works. Two codes only p0420/p0430 ( secondary o2) both have been coded out via Uprev.
What happens is that when the car is being slowed down to a stop the clutch is pressed, the RPMs jump (1500rpm) like I just started the car, back down to idle but takes a second or two to come back down. Going from Back_To_Stock tune to my tune does not change the behavior.
Replaced the throttle bodies (just in case).
Replaced the AF sensors
Still same behavior
I will create a video and post it when I get a chance.
History: This happened only after the battery died, replaced the battery and this is the result.
Now for the upgrades - I have everything from Takeda intake/HFC/homegrown exhaust/Uprev (with the tune I created)
I cannot figure this out - minus going out to get the consult 2 ( I am about to pull the trigger on that ) Can anyone tell me why this car will not stay in closed loop. If there is any parameter you guys need to help me diagnose this let me know.
willdogs
Dec 8, 2015 11:32 AM
leo38cheng
Nov 12, 2015 06:49 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
