Headlight replacement
Old Mar 24, 2014 | 02:57 PM
StratoMX5's Avatar
Smile Headlight replacement
Replacing my cracked headlight assembly on both right and left sides finally. I can't stand looking at it anymore.
Any feedback on if I should buy OEM again? Afraid if I do they'll just end up cracked again.
Also, are there any good aftermarket assemblies out there worth buying.
Old Mar 24, 2014 | 05:03 PM
Austin713's Avatar
where are you driving that this is happening? ive had my car for over 5 years and never had this issue.
Old Mar 24, 2014 | 09:45 PM
StratoMX5's Avatar
The car came from California. We purchased it in 2009 with 21k miles on it. We live in Central Texas. I've no clue honestly why it happened. The car isn't garage kept, but neither is my 2003 mx5 and no headlight cracking issues there.
Old Mar 24, 2014 | 10:16 PM
ScraggleRock's Avatar
OEM is the only way to go for headlights. Everything else is ricey and or cheap.
Old Mar 26, 2014 | 11:56 AM
Austin713's Avatar
my guess is youve caught some big rocks from a semi on the highway or something. i drive 290 every day and have had my windshield repaired 3x because of that.
Old Mar 26, 2014 | 03:07 PM
ChinkyChoy's Avatar
before you install the headlights send em off to get them painted and moded by one eighty or someone who does that kind of stuff. other than that i dont think there is another option
Old Apr 9, 2014 | 12:47 PM
namanc6's Avatar
Good read. I myself just shattered my headlights due to rear ending a semi; that was the only damage, thank God. Anyway, I'm looking at carid.com and found a decent price for a non oem headlight. Just under $300 for the driver side assembly. I'm hoping this is a good route, cuz infinitipartsusa.com want just under $900 for the oem headlight assembly.
Old Apr 25, 2014 | 04:58 PM
StratoMX5's Avatar
I found OEM headlights via partsgeek. I know they are from a wrecked vehicle, but I figure I'd check em out for only $276 each. I have 30days to return and they offer a free 1 year warranty. I'll update when they arrive.
Old Apr 25, 2014 | 10:40 PM
Urbanengineer's Avatar
Are they 06+ projectors? I am buying that stock up if thats true...!
Old Apr 26, 2014 | 05:59 AM
mishmosh's Avatar
If you have a good relationship with your Infiniti dealer, you might want to see if they can do anything. Infiniti has been known to replace things out of warranty that owners really shouldn't be having an issue with. Very true for the 1st gen G anyways.
If you are talking the fine cracks in the headlight, ie. crazing, many had these replaced under warranty. My right headlight had the same issue and was replaced before I painted the inside shrouds.
Old Apr 29, 2014 | 07:18 PM
StratoMX5's Avatar
The stock image photo they used was the exact headlight that is on my 07 which shows the projector. I presume that is exactly what I'll be receiving. Will let ya know as the headlights come in Thursday!
We asked them about the headlights when it first started to happen, alas they would not replace them. The dealership has been good to us though as they replaced the plastic inserts on the door where the handle is that one uses to pull the door shut as well as the same looking plastic on the steering wheel because the paint was peeling. No charge to us.
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
EasySausage
Jul 20, 2015 03:56 PM
