Headlight sensor
Old May 24, 2014 | 01:24 AM
artkim's Avatar
Headlight sensor
I've been having an issue where my left headlight doesn't turn on automatically at night (right one does). However, if I manually turn on the headlights, the left one will turn on, leading to me think that this might be a sensor issue. I was wondering if anyone knew where I can purchase a new headlight sensor. Thanks in advance!
Old May 24, 2014 | 03:28 AM
Mike45's Avatar
On the dash, all the way in the back there should be a plastic sensor. There is one on pass side and one on driver.
Old May 24, 2014 | 02:13 PM
silverG2007's Avatar
I wouldn't think the sensors for the headlights would be independent. There's no reason I can think of why one should turn on without the other unless a bulb is out or a wire is messed up.
Old May 24, 2014 | 09:50 PM
artkim's Avatar
Good thing is that both headlights still work when I put them on manual.
I took a flashlight and shined the light on the right sensor when my headlights were on auto and the lights turned off. Can't say the same happened for the left sensor. Any other possibilities besides the sensor?
Old May 25, 2014 | 04:31 AM
artkim's Avatar
Never mind, I'm an idiot and should have done my research.
https://g35driver.com/forums/g35-cou...t-ballast.html
Sorry for the wild goose chase and thanks for all the help!
lil beezy
Lights
Dec 23, 2015 05:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
