Idle Hesitatation no Service Engine Light
Old Oct 28, 2014 | 08:32 AM
Dragonslayer's Avatar
I changed the battery about one year ago. And the throttle bodies and maf were cleaned about three to four months ago.
Old Oct 28, 2014 | 09:42 AM
Anybody have a vacuum line diagram for 08 Infiniti g35 sedan? I'm trying to figure out what line I need to pour deadpan in to check for leaks as well what lines I need to be checking. Thanks.
Old Oct 28, 2014 | 10:37 AM
vqsmile's Avatar
I don't have time to look for it at the moment, but I know the vacuum system diagram is in the FSM.
Old Oct 28, 2014 | 12:32 PM
Thank you I found what I needed. I want to give a little bit more description on the issue. The issue has been happening even before I did the tune up while replacing my water pump. The issue was minor just hestitating very minor like every couple of mins now it's 10-30times a min. I have had the battery, clean throttle body, egr value, timing chain, tensioner, coolant, water pump, spark plugs, ignition coils all cleaned or replaced. So anything else you guys think I should check? So far I have done an ecm reset and re-program through dealer, seafoam fuel tank. Next I'm working on pouring seafoam through pvc or if I can find brake booster line to engine.
Old Oct 28, 2014 | 10:35 PM
vqsmile's Avatar
Sounds like you've covered a lot of the most likely suspects. Maybe the the idea of a injector glitching isn't too far fetched there.
Old Oct 29, 2014 | 02:34 PM
Finnkc's Avatar
fuel flow problem? Sounds like you have gone through the usual suspects.
Old Oct 29, 2014 | 03:20 PM
Cylinder 6 misfire detected. So now I'm worried about driving the vehicle around.
Old Oct 29, 2014 | 07:59 PM
vqsmile's Avatar
Random thoughts triggered by that info:
How is #6 injector?
How is #6 coil?
How is compression in #6 cylinder?
How does #6 cylinder hold up in a leakdown test?
Is there any indication of hydrocarbons in the coolant?
Is there any indication of coolant in the motor oil?
Old Oct 29, 2014 | 09:38 PM
ejl22190's Avatar
I may be totally off. But I would suggest a "Idle air volume learn". Just to see if it helps.
It won't hurt to try.
Muski_G
Dec 1, 2023 11:11 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
