what do you guys think about wheel spacers anyone got them?
Old Nov 23, 2015 | 02:52 AM
takeapieandrun's Avatar
Amazon. It's a hunk of aluminum, not much to it.
http://www.amazon.com/s/ref=nb_sb_no...re+25mm+spacer
Old Dec 3, 2015 | 03:34 AM
prince24's Avatar
Would these work ??
Would these work Look at this on eBay:
http://www.ebay.com/ulk/itm/191156136051
2X HUBCENTRIC WHEEL SPACERS ADAPTERS ¦ 5x114.3 ¦ 12X1.25 ¦ 66.1 CB ¦ 20MM THICK
Old Dec 3, 2015 | 09:01 AM
VenomGT9's Avatar
wrong center bore...need 73.1
Old Dec 3, 2015 | 11:31 PM
Urbanengineer's Avatar
73.1? Isn't coupe 66.1?
Old Dec 4, 2015 | 07:04 AM
VenomGT9's Avatar
Isn't this for a sedan though?
Old Dec 4, 2015 | 10:23 PM
BradMD_96's Avatar
both sedan and coupe are 66.1
73.1 is for most aftermarket wheels.
You can get wheel spacers with 66.1 center bore hub side and 73.1 center bore on wheel side but they would be more expensive or have to be custom made. Best thing is to use a spigot ring (fills the space) either on the hub to spacer - with 73.1 bore - or on the spacer to wheel side - with 63.1 bore spacer.
I have run spacers which had one center bore that was larger than the car hub and smaller than the wheel bore so I was using a spigot ring on each side.
Old Dec 7, 2015 | 04:08 AM
The way I see it spacers are for OEM wheels. In our case 66.1 hub bore. Don't get spacers on aftermarket wheels unless you absolutely can't find the right offsets, because they only add to rotational mass.
Old Dec 7, 2015 | 01:28 PM
vqsmile's Avatar
I see people keep mentioning the increased rotational mass, but these actually do very little to increase that. The greater effect of these will be toward the overall unsprung mass. Rotational mass is a function of radius, so a 1.5 lb. increase at a mere 2" to 3" from center is virtually nothing compared to something like a poor (heavy or larger diameter) tire or wheel choice, where fully 2, 3, or more lbs of extra mass is located at a distance of 12" or so. Then ironically, comes the addition of the BBK, (you know, to slow down these increasing larger centrifuges) with another half dozen pounds of weight pushing clear out to 7" from center.
Truth be told, the vast majority of people that run larger wheels, which of course require heavier tires, are directly shifting weight further from the center of rotation, and thus are severely increasing their rotational mass as well as their unsprung mass over stock. In proportion, it just seems kind of silly to worry about a little more weigh right at the hub.
Basic physics guys.
Old Dec 7, 2015 | 01:33 PM
PGg35s's Avatar
Anybody here running spacers on sport suspension and OEM sport 18's? I want to see some pics. Thinking about putting some on mine.
Old Dec 7, 2015 | 01:38 PM
PGg35s's Avatar
Nevermind, did a search and found pics. Sorry
Old Dec 7, 2015 | 03:37 PM
ScraggleRock's Avatar
Basic physics guys.
Yes.
Old Dec 9, 2015 | 03:01 AM
I have the sport 18's, but I am lowered on coilovers:
http://imgur.com/a/w3gpd
Old Dec 9, 2015 | 01:23 PM
prince24's Avatar
My car has the same color body and rims I just would like mine to pop like yours what exactly did you do to get that look . The setup
Old Dec 9, 2015 | 07:33 PM
saywat?'s Avatar
i got aluminum anodized spacers from ebay. works great wasnt expensive either. and its one piece hubcentric unlike some of the older style where its 2 peices. looks irritating to deal with in the future. i like the one piece action
Old Dec 15, 2015 | 03:19 AM
  #30
Lowered almost 2" on Tein Street Basis coilovers. 25mm spacer in the back and 32mm in the front. You're gonna need longer studs on the front for such a fat spacer. The wheel finish is plastidip black plus silver metalizer. Everyone thinks my wheels are powdercoated, thats how they appear in person. Keep in mind if you don't have the sport rims your offsets will be different. Also my car was pretty dirty in those pictures it looks a lot nicer with a fresh wash and tire shine.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
dseet
Oct 11, 2015 12:40 AM
Chrisw
Oct 5, 2015 07:06 AM
BradMD_96
Oct 2, 2015 04:03 PM
