P0455 error
Old Aug 25, 2016 | 02:18 PM
ggaudreau's Avatar
P0455 error
My service light came on a while back and I got the code from the OBD code reader.
From checking on the net, it looks like a leak on the air pressure gas tank. Am I lookiing in the right area?
Guy
Old Aug 25, 2016 | 11:56 PM
vqsmile's Avatar
Guy
You are looking in the right direction. The most common cause is a loose gas cap. Before you get carried away, have you checked that?
http://www.autocodes.com/p0455_infiniti.html
Old Sep 14, 2016 | 02:18 PM
ggaudreau's Avatar
Yes I did and the gas cap is securly on.
Does anyone know where the EVAP canister purge volume control solenoid valve is on a G35 , 2008.
Thank you
Guy
Old Sep 14, 2016 | 05:24 PM
vqsmile's Avatar
Thank you
Guy
See the Factory Service Manual, Engine Control section (EC), pages EC-23 and EC-28.
Basically, it's in the engine compartment, between the back of the intake manifold and the firewall, just to the right side of center. The "S" bend hose is on the left, and the solenoid is on the right. (From the driver's perspective)
EDIT> Here's a link to the FSM: http://www.nicoclub.com/FSM/G35/Sedan/2008/
Old Sep 15, 2016 | 01:07 PM
ggaudreau's Avatar
I will look and get back to you - Thanks - Guy
Old Sep 29, 2016 | 08:34 PM
dun5081's Avatar
Guy,
Did it work my 08 keeps throwing same code. I tried tightening the cap then a replacement cap with no luck.
Old Sep 29, 2016 | 08:37 PM
dun5081's Avatar
Link doesn't work. Tell me they are not a valid pdf?? Rob
Old Sep 29, 2016 | 08:58 PM
vqsmile's Avatar
I just tried it again and it works fine for me. :
Old Oct 17, 2016 | 11:24 AM
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
So I replaced the charcoal canister and the purge valve but the ses has come back up and I'm going to get it scanned to see what code comes back up and I'll let you guys know. It was the purge valve but I didn't realize this was for 07+ G35's. ㄴㅇㄴ
Ltdport
Jun 13, 2016 10:49 PM
G35@25
May 30, 2016 10:46 PM
Dom_35
Steering & Suspension
May 29, 2016 01:24 PM
FuriousVegan
May 27, 2016 11:44 PM
PerryLancaster
May 27, 2016 08:53 PM
