Fuse for auto dimming mirror?
Old Mar 9, 2018 | 04:34 PM
stockae92's Avatar
I am trying to find if there is a fuse for auto dimming mirror?
I looked at the owners manual (PDF) but couldn't find it.
I am trying to disable it because my tint is dark enough for me at night
Old Mar 10, 2018 | 11:17 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you weren't worried about disconnecting your homelink garage door controller as well you could just pop the finisher off the mirror and unplug the harness. Unfortunately you can't just pull the fuse because it is the same fuse for almost all interior functions.
Old Mar 11, 2018 | 11:01 AM
Urbanengineer's Avatar
Do you have anything hanging behind the mirror? Mine used to do the same thing.
Old Mar 11, 2018 | 11:15 AM
cleric670's Avatar
BANNED!!!
What VLT tint are you using btw? I have 20% which feels perfect and my anti-dazzle mirror pairs well with that tint.
Old Mar 12, 2018 | 01:38 PM
stockae92's Avatar
I am not sure about what percentage it is.
but when the tint and auto dim mirror at night, its hard for me to tell if crown vic is way back somewhere
Old Mar 12, 2018 | 01:39 PM
stockae92's Avatar
thanks for the info.
i already unplugged the mirror, i am just wondering if there is a fuse to disable it so i don't have a plug hanging around if you know what i mean.
Old Mar 18, 2018 | 07:13 PM
joefootball's Avatar
I'm going to look his up
Old Mar 18, 2018 | 08:33 PM
FreshLikeAG's Avatar
Can't you just tuck it behind the headliner
Old Mar 18, 2018 | 09:07 PM
cleric670's Avatar
BANNED!!!
I don't feel like pulling mine off just for the sake of exploration but I thought there was a physical connector BEHIND the plastic trim piece that connects the mounting base to the headliner. If you can't just unplug the harness and keep it hidden behind the trim then you could always cut wire the black wire which is the ground for the mirror, it shouldn't be able to function at that point. Make sure to cap the ends of the wire.
Old Mar 18, 2018 | 09:12 PM
tbd
Old Mar 18, 2018 | 09:13 PM
Originally Posted by joefootball
tbd
you should be banned
Old Mar 19, 2018 | 12:35 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Yeah. It appears he's trying to hit 100 posts so he can sell his sedan.
Old Mar 19, 2018 | 12:43 PM
G2B35AGN's Avatar
And he doesn't need 100, rules have changed: 5 posts and 15 days. He was advised but seems slow to grasp.
Old Mar 19, 2018 | 02:50 PM
stockae92's Avatar
Thanks guys for all the suggestion.
The disconnected plug behind the mirror doesn't bother me too much. I just wanted to if there is a better (and easily reversible, i.e. no cutting required) to make it look clean.
Maybe I will just black zip tie the plug to the base of mirror, or electric tape the connector and see if I can plug it back it and it still won't make any connection.
no biggie on this
Old Mar 20, 2018 | 09:17 AM
20 Year Member
What if you covered both sensors with electrical tape or paint?
