Please help just replaced wheel bearing assembly and cv axle
Old Nov 28, 2018 | 03:22 AM
Treimonenq's Avatar
G35 base sedan
Hello all, I just replaced the rear wheel bearing hub assembly and cv axle on my 07 g35 sedan driver side I followed what seems to be simple instructions on how to do this, put everything back in place went to test drive it only to hear a grinding/ rubbing/ clicking noise coming from the axle I just worked on I’ve tried to research as much as possible and nothing. I also looked up the splines count on my wheel hub which is 32 and the cv axle splines count is 29 is this normal ?? I bought the parts from o reily and of course they didn’t tell me anything to expect when doing this job. The sound only happens when I’m in either reverse or drive, Did I do something wrong when replacing these parts ? Am I missing a piece? I saw an abs tone ring mentioned online but the new one didn’t come with it is this what’s causing the noise? I’m completely stumped any feedback would be appreciated thx
Old Nov 28, 2018 | 05:46 AM
Scorpi0's Avatar
Did u by any chance install the brake rotor shield on backwards?? That can rub on the rotor and cause some nasty noise.
Old Nov 28, 2018 | 09:53 AM
coffeysm's Avatar
Check the axle nut is torqued properly along with everything else. If you have RWD the ABS tone ring is on the output shaft by the diff the half shaft bolts into. I'd also check the brake shield.
Old Nov 28, 2018 | 09:53 PM
Treimonenq's Avatar
G35 base sedan
I didn’t have to take the brake shield off when installing the wheel bearing I don’t remember it even moving during the install process it sounds like the cv shaft is bouncing inside the wheel bearing
Old Nov 28, 2018 | 09:57 PM
Treimonenq's Avatar
G35 base sedan
do you by any chance know the torque specs ?? It’s a weird because I’m not even moving and the sound happens I’m just holding the brake while in reverse or drive and the sound starts and do I need a tone ring I don’t remember seeing it on my new cv shaft but it was definitely on the old one
Old Nov 29, 2018 | 11:31 AM
coffeysm's Avatar
It only happens when you hold the brake? The tone ring isn't on the actual axle at least if you have RWD, unless the G37 is different. The flange the axle bolts to that comes out from the diff is where the tone ring and ABS sensor sit. Your ABS light would turn on also if it couldn't read the tone ring. I don't know the exact specs, but I did both my rear wheel bearings and just tightened it hard and then used a breaker bar with a pipe to give it a little extra snug.
Old Nov 29, 2018 | 03:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would take the wheels off and inspect the splines, you should DEFINITELY have the same number of splines on both the shaft and hub. If you don't then it will quickly destroy itself if you can even get it assembled. They may have sold you a defective part that was meant for a different vehicle.
Old Nov 30, 2018 | 01:24 AM
Treimonenq's Avatar
G35 base sedan
ok thanks for info and no I don’t have an abs light come on this is driving me insane honestly and yes it only happens when I just holding the brake it’s in my garage so once I heard that noise I never moved the car I thought I would mess something up worse this can’t be that hard of a repair to do
Old Nov 30, 2018 | 01:30 AM
Treimonenq's Avatar
G35 base sedan
I really hope this is my problem but yes they are definitely different spline counts but everyone I’ve seen online has a spline count of 29 for axle and 32 for wheel bearing even my old wheel bearing has 32 I didn’t think to count the splines on the shaft before I turned it in for core charge I didn’t think I was going to run into this problem I will take everything apart this weekend and try again I wish I knew for sure that the splines are suppose to be different honestly I would have to take off the shaft on the passenger side to find out which I didn’t really want to do but at this point I’m all out of options. Would the dealership share any info on my problem?
Old Nov 30, 2018 | 03:36 AM
Scorpi0's Avatar
U might be able to count the splines on the shaft from under the car without taking it all apart....maybe!
Old Nov 30, 2018 | 06:37 AM
Treimonenq's Avatar
G35 base sedan
that would be nice I need to find out the spline count ASAP I do believe that’s my problem it’s hard when no one around me sells it, I may need to talk to someone at the Infiniti dealership and hope they could share some info
Old Dec 4, 2018 | 09:36 PM
coffeysm's Avatar
I just responded to your new post. But, the rear wheel hubs I purchased when I did mine do have 29 splines. I put a link to them as well and they also sell a kit for like 55 bucks.
n1smojunkie
Steering & Suspension
Jun 24, 2018 02:43 PM
G_zus
Aug 9, 2016 08:42 AM
studio54
Jan 22, 2014 12:06 PM
