Has anyone ever changed a rear CV shaft and or wheel bearing hub assembly???
Old Dec 3, 2018 | 07:04 AM
Treimonenq's Avatar
G35 base sedan
I was wondering how is this process possible with the wheel bearing splines count being 32 and CV shaft splines being 29 shouldn't it match?? If anyone has any idea or experience with this please please please reply I don't want to put my car in the shop just for them to fix it and it be something simple I'm missing and charge me an outrageous price
Old Dec 4, 2018 | 09:29 PM
coffeysm's Avatar
Well, I've done both my rear wheel bearings over the summer. I also took out my passenger side axle shaft to change the rear diff seal that was leaking, but I didn't count the splines.
I just looked on RockAuto and the rear wheel hub I bought; has 29 splines as well. Is it possible you bought the wrong hub?
https://www.rockauto.com/en/moreinfo.php?pk=8327128&cc=1432547&jsn=406
Old Dec 5, 2018 | 12:44 AM
Treimonenq's Avatar
G35 base sedan
I've bought it from O'Reily's and they assured it was the right fit my old one I took off was also a 32 splines wheel bearing hub but if the CV shaft is 29 and this one from rockauto is as well I'm going to get and get a wheel bearing pressed on and be done with this thanks so much for the help I also has access to a 29 splines count wheel bearing assembly off of a 08 350z it's still in good condition but I wasn't sure it would fit I may get that one as well, install it and see if my problems continue
xclusivestylez
Steering & Suspension
Aug 16, 2017 02:57 PM
G_zus
Aug 9, 2016 08:42 AM
studio54
Jan 22, 2014 12:06 PM
