A/C Compressor Clutch intermittent
Old Aug 26, 2019 | 12:11 PM
blackandwhite's Avatar
Okay...I am having some issues with overheating. And A/C.
The compressor clutch is disengaging and re-engaging. At highway speeds, I can notice the air go from back and forth from cool to hot. And shortly after, the engine temperature rises, but it returns to normal once I turn the A/C off.
At idle, at stoplights, I've noticed the clutch engaging and disengaging over and over. The compressor, clutch, and A/C fan assembly are all new. With the compressor and low pressure switch just being replaced over the weekend.
Any suggestions?
Old Aug 26, 2019 | 07:09 PM
Scorpi0's Avatar
The compressor engaging and disengaging is normal operation.
Old Aug 26, 2019 | 07:12 PM
I know that's normal, but not as frequently as it was doing. I'm riding in freeway traffic and I can feel the air get cool then switch back and get warm and then switch back and get cool over and over again. Then when I got to a stop light sitting still it kept coming on and off again blipping my idle up and down. Continuously engaging in re-engaging. Not just occasionally
Old Aug 26, 2019 | 11:05 PM
Scorpi0's Avatar
Hmm. I would try getting a refrigerant refill. It just might have gotten low over the years and just needs a bit more pressure. Cheap and easy and might fix your problem.
Old Aug 27, 2019 | 09:07 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If you have a radiator / cooling problem and your engine temp gets too hot it will shut your AC off. If you have a OBD scanner you can watch the actual temps that it is getting to before AC shut down. If you have a advanced scanner it may monitor the refrigerant pressure too.
Old Aug 29, 2019 | 12:04 PM
Joenavy85's Avatar
G35x Base
This is my guess. The compressor will cycle oddly when the charge is low. I'm guessing these have a built in protection circuit that prevents short cycling, which will happen with a low charge, to prevent damage to the compressor. Basically it will control the duty cycle to prevent it from re-engaging for a certain amount of time after dis-engaging, which would explain why you feel the air warm up (not enough refrigerant to flow and not enough time has passed to allow the compressor to re-engage).
Old Dec 22, 2019 | 04:51 PM
Cabrito's Avatar
07 G35S 6MT
From my reading of the shop manual, a bad pressure sensor may be the culprit. It's atop
the AC fluid reservoir on the passenger side of the radiator.
Dan
Old Dec 22, 2019 | 05:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can easily troubleshoot nearly any AC problem by simply hooking up the manifold gauges and watching them.
sean_t0
Sep 17, 2023 10:57 AM
CoryGable
Apr 23, 2018 05:54 PM
losvaldez
Jul 14, 2011 11:53 PM
wdgolden
Drivetrain
Feb 10, 2010 06:49 PM
