Turning vibration
Old Oct 29, 2019 | 01:09 PM
Joenavy85's Avatar
G35x Base
Turning vibration
Did some searching here with no luck, maybe I'm just not hitting the right keywords. I get a weird noise/vibration when turning sharply at low speeds. It's not constant, and it's not consistant. Sometimes it makes the noise (sort of a groaning noise for about a second, as if something rubs briefly) and sometimes it doesn't. Sometimes while backing up, sometimes while going forward. I initially thought i had something rubbing my tires, but i checked the tires when I rotated them 2 weeks ago and saw nothing suspicious. Any ideas?
Old Oct 29, 2019 | 01:32 PM
Urbanengineer's Avatar
Are they stock wheels and tires? Sounds like some rubbing.
Old Oct 29, 2019 | 01:33 PM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Look at your fender liners and see if the tires are rubbing against them. Should see a mark of some kind where the tires are rubbing the road dirt off. They won't leave a mark on the tires. May have a screw missing or some loose clips.
Old Oct 29, 2019 | 06:52 PM
Triton3.5's Avatar
How many miles? poss. wheel bearings, mine just did this as you described, ended up replacing both fronts... this is on an AWD btw...
Old Oct 29, 2019 | 08:50 PM
Joenavy85's Avatar
G35x Base
Factory wheels, OE size tires, I'll crawl under tomorrow and check the fender liner. Just over 159k miles, less than 15k on the wheel bearings.
Jeff T
Sep 30, 2015 02:00 PM
asitmc
Nov 20, 2009 10:56 PM
ThirstyTurtle
V36 Brakes, Suspension, Wheels & Tires
30
Apr 17, 2009 10:25 PM
GfortheCPE
Jul 13, 2005 11:12 PM
Gizmos_G35
Mar 6, 2005 11:57 AM
