High pitched vibrating sound when above 3k rpm
Old Oct 31, 2019 | 11:28 PM
Chokopokkin's Avatar
G35x
Unhappy High pitched vibrating sound when above 3k rpm
Hi guys, I've been getting a high pitched sound coming from my car when I rev it above 3k rpm. It sounds like a vibrating type of noise. It happens while driving or parked. Could it be an engine problem?
Old Nov 1, 2019 | 04:18 AM
909's Avatar
909
Your mom's boyfriend
Could be anything. Check the cat heat shield clamps.
Old Nov 1, 2019 | 12:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Try to isolate exactly where the noise is coming from. Have someone else work the throttle while you inspect the engine bay and under the vehicle to find out exactly where it's coming from.
Old Nov 2, 2019 | 02:07 AM
G35x
It doesn't sound like it's coming from the front of the car. I can't hear it at all under the engine. It's somewhere in the middle towards the back. Is it the catalytic converter? But why is it so high pitched?
Old Nov 2, 2019 | 01:13 PM
cleric670's Avatar
BANNED!!!
It's really hard to tell from the video, sounds like a "ringing metal sound" sort of which can be caused by metal parts vibrating against one another. I think you should have it inspected at a muffler shop, that way someone can literally stand right under the car with a stethoscope and a long screwdriver and poke around on things while someone else holds the throttle right where it's making the noise.
DGrantG
May 2, 2016 03:42 PM
SlickSilverG
Apr 17, 2013 12:36 AM
csdstudio
Feb 25, 2009 08:15 PM
diablo1356
Nov 10, 2007 03:58 PM
ThatsMyG
Jul 5, 2007 01:14 PM
