Window switch
Old Nov 3, 2019 | 08:47 PM
Kuynichan's Avatar
6MT G35 Sport Sedan w/ Tech Package
Window switch
Recently one of the switches on my window control snapped off and I don’t remember how. Then recently bought an aftermarket one off amazon, but now doesn’t have some of the features before. Can’t roll down the windows remotely (w/o being in the car) and doesn’t have the power window function. I looked at auto parts stores around me but they’re around $800. Is it wort trying to find a new one, or is there another way I could swap some pieces out.
Old Nov 3, 2019 | 09:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you still have those broken pieces of plastic I would just use Loctite Pro super glue or Gorilla glue and carefully glue them back on, then snap the switch back into place.
Did you check eBay? It's a great resource of used OEM components exactly like that. Driver-side switches are usually about $50 and other doors with a single button are typically about $25.
Old Nov 3, 2019 | 09:47 PM
cleric670's Avatar
BANNED!!!
Also you local pick-n-pull wrecking yard, I would get the exact part number and cross reference how many vehicles it was used in. Probably the same switch for a V36 platform was used in G25, G35, G37 is my guess. Maybe you'll get lucky and it's also the same switch in the Maxima/Altima.
Infinipartsonline.com is typically who I use to look up part numbers for stuff like that.
Old Jul 14, 2021 | 01:23 AM
DanialInfiniti's Avatar
G35 Journey
Hye guys, do I need to disconnect the battery to replace the window switch? I read somewhere that since when ignition isn't on, there is no juice going to window switch, you do not need to disconnect the battery.
Old Jul 14, 2021 | 02:02 AM
909's Avatar
909
Your mom's boyfriend
Removing the battery stops accidental shorts. But I've installed that switch a bunch of times without removing the battery. You should be fine.
Mario'sG
V36 Interior, Exterior & Lighting
Mar 9, 2018 11:25 PM
Kadeem Brown
Aug 23, 2016 02:21 PM
esotericrider
May 13, 2016 02:48 PM
malicemethods
Jul 29, 2014 05:50 PM
