Left side speakers not working 07 G35x
My left side speakers (front and back) suddenly cut off one day. Ive tried messing with the fader but when I put it to the left side there is no sound. Occasionally it will crackle and pop that usually happens when I put the volume all the way up with the fader set to the left. Anyone have any tips to fix this? I have taken out the headunit and put it back to make sure there were no loose connections. Also unplugged and plugged back in the cables on the amp. Any help would be appreciated.
This.
Must be annoying as hell just knowing it's not working properly. Couldn't imagine driving around with a half broken audio setup . I'd prob start simple. Unplug the broken speaker , test with a working crappy speaker. If you hear sound .... problem solved. Your speakers are f*ucked .
If you still have no sound test the wire coming out of the head unit . Remove the head unit , stick 2 wires into pinouts with a working crappy speaker. If you hear sound .... problem solved. Your wiring is f*cked, bad connection somewhere.
You could probably open the headunit and look for ovb signs of a something wrong but most people won't.
Do those 2 before you swap your headunit or amp with a junker .
Can you please list suggestions? I haven’t researched OEM im not sure what it is.
thanks.
edit: I found someone selling a radio unit. It was originally for the g35 with the nav package. I don’t have the nav package in mine but would the radio replacement still work? Thanks
thanks.
thanks.
thanks.
Great news. Everything works like it should. Bought a used radio unit online. Just took apart the headunit and swapped em out. Thank goodness because I could not take only listening to music from the right speakers for much longer. All in all it cost me $48 for the replacement. Pretty cheap fix considering I spent $115 for a car audio place to tell me the problem.
Scorpi0 (01-24-2020)
Originally Posted by Daniel P
Well I should thank you because you saved me the $900 they said it would take to fix it. I had no idea I could just swap in a used one until you mentioned it. Thanks.
![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
Scorpi0 (01-25-2020)
